Air fuel problems
Old December 16th, 2008, 04:46 AM
Bunser's Avatar
Air fuel problems
I have a 70 W31 engine with the original quadrajet carb.When dyno tested the A/F readings were ranging from 7 to 9. Just a bit rich.Any suggestions (except from Norm) would be appreciated.Thanks.
Bunser is offline
Old December 16th, 2008, 06:35 AM
cutlassefi's Avatar
Air/Fuel
Gotta check a bunch of stuff, the bowl plugs, they normally leak, fuel pressure, yes the primaries do have metering rods, are they sticking etc. Needle and seat, good condition, set right? If possible try another carb on it. Or you maybe have to send it out to a more competent rebuilder. Good luck!
cutlassefi is offline
Old December 16th, 2008, 07:37 AM
Oldsdruid
rocketraider's Avatar
W31 shouldn't have primary metering rods, unless everything the factory put out about them is a lie...
Are these A/F readings at WOT or thruout pull range?
rocketraider is offline
Old December 16th, 2008, 10:18 AM
cutlassefi's Avatar
Air/Fuel
Sorry guys, every Quadrajet I've ever seen had primary metering rods. My mistake.
Old December 18th, 2008, 04:12 AM
Bunser's Avatar
It probably doesn't interest too many,but, on runs three days apart, the following results were obtained.On the first day the readings ranged from 11.4 to 14.0. Three days later (same secondary rods and same hanger) it ranged 7.8 to 9.8 with rpm range from 3000 t0 5500.
His explanation was different atmospheric pressure or air density or maybe tooth fairy dust. I'have to believe that his test instrumentation needs calibrating/overhauling! Any comments welcome.
Bunser is offline
Old December 18th, 2008, 08:47 AM
cutlassefi's Avatar
Air/Fuel
I agree. At around 8.0 to 1 air/fuel I'm pretty sure it would have been belching black smoke. May want to try someone else, at the very least different equipment.
chasman414
June 25th, 2020 07:05 AM
KQQLCAT
September 20th, 2015 05:49 PM
1965cutlassragtop
July 15th, 2012 06:26 PM
2blu442
May 1st, 2011 07:29 AM
dandl1862
August 14th, 2006 03:29 PM
Quick Reply: Air fuel problems
