Advice on carb, and headers
Old Oct 11, 2009 | 01:55 PM
pappy86's Avatar
I am putting a oldsmobile 350 together for my daughters car a 1976 cutlass supreme. The motor is a 1970 vintage with #6 heads. The block is now bored .30 over, with TRW 2320F-30 pistons installed, compression should be around 10.2 to 1 i believe. the heads are 63cc, I bought a comp cams valvetrain kit which included studs, rockers, and guide plates. the cam is a comp cams extreme energy 274 kit which included springs and all other hardware. the specs are 236-240 duration and 520 523 lift. The intake is a Edlebrock 7111. I need advice on who makes the best fitting header that does not need any cutting, and what carb would work best with this set up. I am thinking of a 750 speed demon with electric choke and vacuum secondaries. The car will be driven every day. It has a 2500 stall, and 3.90 gears waiting to be installed. This is my first olds, bought the car last month only has 46000 miles and is wearing original paint. the stock motor has low oil pressure at idle when warm, and rattles when revved up in neutral when warm, so went ahead and built new motor while still driving the old one. Sorry for the length first post.
Old Oct 11, 2009 | 02:05 PM
svnt442's Avatar
For an everyday car I'd go with a Quadrajet. When properly done they are awesome carbs.
Are you swapping in a 200 4R trans to go with those gears?
Old Oct 11, 2009 | 02:18 PM
pappy86's Avatar
That is plan for the spring as winter will soon be here and the car will be put away. The quadra jet on my stock motor stumbles bad when the choke comes off, it runs good until then, and runs good when at wot. just stumbles real bad under part accelaration. I would not be against using it, any good places to send them out to.
Old Oct 11, 2009 | 02:28 PM
svnt442's Avatar
From everything I have seen Sparky is the man when it come to them.
http://www.sparkyscarbs.com/
Give him your combo and he'll get it straight for you.
Old Oct 11, 2009 | 02:40 PM
jims2000lt's Avatar
11.52 @116
I would sugget a set of Hooker compition heards for this combo. That is going to be a healthy cam for that motor. I used the same cam in a 455 and you will be lucky to pull enough vaccume for power brakes. You will also need adjustanle rockers to run this. It might be borderline but close. Whats the intended use for the car really? Its going to be something to get used to for a DD.
Old Oct 11, 2009 | 02:41 PM
pappy86's Avatar
Thanks I will do that, now just need to figure out headers. here are some pictures of the old girl
Old Oct 11, 2009 | 02:47 PM
pappy86's Avatar
It will be here sunny day driver around town, and weekend track car for fun. Thanks for the header recommendation. Was this cam tolearable for everyday driving. I have only built big block fords before and those cam events are okay in them for the street. I was going to go with the 268 extreme but was a little worried it would not get here through the quarter mile with the gear we want to run.
Old Oct 11, 2009 | 03:01 PM
svnt442's Avatar
For some reason the links to your pics don't work.
Old Oct 11, 2009 | 03:10 PM
pappy86's Avatar
I am not very good with computers. Why does hooker say except cutlass supreme for my year car.
Old Oct 11, 2009 | 03:16 PM
pappy86's Avatar
I think I got a picture in my sig now.
Old Oct 11, 2009 | 03:45 PM
70 cutlass s's Avatar
Go to summit.com they have headers for your car.
Old Oct 12, 2009 | 05:54 PM
jims2000lt's Avatar
11.52 @116
Everyone has there own definition of tolerable so all I can say is it was okay but I wouldnt be driving it to work everyday or anything. That cam with a performer and 3.42 gears got me to 11.75 in a 3500pound 442. This is with a 461 so the cam was probably a little tamer for me cuz of the cubic inches.
Wyze
Mar 18, 2012 01:59 PM
seok
Mar 23, 2011 10:55 AM
montyman71
Jan 26, 2011 06:55 AM
RustBoxBrad
Nov 11, 2009 08:31 AM
ej69
Sep 23, 2009 07:54 PM
