Accel Distributor
#41
An excellent synopsis and a great set of links.
Thank you for posting them!
I do need to correct one detail, though, so that it doesn't propagate
The stuff that you put under the module to improve heat transfer to the base and prevent overheating is NOT dielectric grease.
It is heat sink paste.
Dielectric grease is an electrically insulating silicone-based grease that will not improve heat transfer, and is not what you should use.
#42
Might be an option don't know if they are available for olds just yet. Also have you considered raising the air cleaner base ? Most autozones carry the air cleaner adapters which can raise your air cleaner up to I think 4 inches. Just a though if you only need a few inches of clearance.
#44
Borg Warner used to sell the small plastic packs in bunches of 10, not sure they do anymore.
#45
#46
Last time I was messing with an HEI & needed some heat sink paste was @ 5 years ago.
Round' here ... most people didn't even seem to know what it was & treated you like were some kind of moron.
Heat sink paste ?.
Yeah sure buddy ..... turn left down aisle 3 when you get to the quadraphonic 8-track player display.
Go down to the end of the aisle & check the bottom shelf on the RH side.
If you hit the end cap display with the bias ply's you've gone down too far.
Heat sink paste ?.
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
#47
I think the stuff for CPUs is silicone based (clear), and the stuff for auto use is like lith based or something, it's usually yellow. Not sure if they are interchangeable or not.
Reason most don't ask for it is that it usually comes with a new module. Counter-folks don't see it because it's in the box, out of sight, out of mind.
#48
The clear stuff is dielectric grease. If it's in the packet in the box with the new module, don't use it. (I have gotten it in the box with a new module).
defiant1
January 7th, 2015 04:59 PM
