76 350 rocket
Old Apr 30, 2009 | 06:19 AM
rocketolds350's Avatar
76 350 rocket
does anyone know what the timing should be set at i think its retarted runs bad
Old May 1, 2009 | 03:22 AM
Yellowstatue's Avatar
Smile Before it's too late
Holy smokes, depending on what 350 you have it could be 12 degrees BTDC for an L32 at, and L77 at, or 20 degrees BTDC for L34 excp. Calif. and your rear axle ratio comes into it too...what do you have??
Old May 1, 2009 | 04:03 AM
Welcome
Welcome aboard
Tell us a little about your car and engine.
Old May 1, 2009 | 06:06 AM
Smile 76 350 rocket
i have a 1980 Chevy C10 with a 350 olds engine in it i only no the year because i looked up the heads code 411929 thats the only way i identifyed it as a 76. it runs good until the secondarys open so it runs good on the mains 4-barrel q-jet
Old May 1, 2009 | 06:08 AM
Cool 76 rocket 350
I dont know what car its out of ?
Old May 2, 2009 | 02:26 AM
Smile Time to play
Well in that case you might as well start with 12 degrees and go up from there to 20 and see what happens
Old May 2, 2009 | 12:05 PM
Cool 76 rocket 350
ill try it and also when i hit 45 mph she sputters when the pettle is to the floor feels like no power
Old May 3, 2009 | 11:11 AM
76 rocket 350
i think i might have a 403 it says 403 on the timing chain cover
Old May 4, 2009 | 06:32 PM
Old May 5, 2009 | 04:44 AM
Oldsguy's Avatar
Past Administrator
so, are you going to change your user name then?
Just kidding. You may simply need a good all around tune up. Does it sputter after a slow acceleration up to 45 mph or does it sputter when you "tromp on it" to accelerate quickly? Doe is sputter if you "tromp on it" in lower gear as if you were trying to do a burn out? Do this: with the engine turned of and cool take the air cleaner element out and remove the air cleaner housing. Look down into the primaries (wear safety goggles or glasses) and give the linkage a quick pull back, you should see two streams of fuel spurt into the primaries, one for each primary. Also inspect the accelerator pump area on the carb looking specifically for a wet look near the top gasket as if fuel has leaked/seeped there. This may indicate a need for a good carburetor rebuild if you find any abnormalities. If not, you may have to look further into your vacuum advance and timing setup.
Old May 5, 2009 | 06:03 AM
Question 76 350 rocket
when i tromp on it it sputters it sputters alot and the gas also leaks out the gasket but this is a new carb that i rebuilt and u can smell the gas after it has been driven and then parked and also my distributer cap moves to easy i can turn it with one hand when i first fire it up and let it warm up it has power but then i think its getting to much gas and fludding its self out and it also runs better without an air cleaner becausr then it gets more air but i keep the air cleaner on.
Old May 5, 2009 | 07:54 AM
citcapp's Avatar
You distributor should not move at all. The bolt clamping the distributor is place is loose thats why you timing is changing all of the time. Set the timing and tighten the bolt so the distributor does not move. I am not a carb expert so I cannot help with that problem except to say it should not be leaking, sounds like a faulty rebuild to me.
Old May 5, 2009 | 01:21 PM
76 rocket 350
ill try it
69OLDSCUTCONV
Feb 1, 2011 06:09 AM
cutlassKing
Nov 29, 2010 03:05 PM
gscott819
Jul 28, 2009 07:02 PM
esisson
May 22, 2008 07:47 PM
<Eddie>
Nov 1, 2005 07:30 PM
