75 olds
Old Dec 4, 2021 | 08:26 PM
michael l's Avatar
75 olds
i have a 1975 cutlass supreme with a very uninspiring 350 what can i do iot is a low miles engine just gutless
Old Dec 4, 2021 | 09:00 PM
gs72's Avatar
72Cutlass S
Without tearing it down and adding pistons to raise the compression into the 9.5 to 1 range and adding good cam, intake and exhaust combo not much. But you could consider upgrading the rear gearing to the 3.23 to 3.42 range. This will give it a good kick in the pants and feel like you added some hp to the engine.
Old Dec 4, 2021 | 10:20 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You have 165 hp 275 ft/lbs of torque V8 with a 2.52 first gear and probably 2.56 rear gears in a 4,000 pound car. Do a compression test and put an oil pressure gauge to see how healthy it is. Does it still have the catalytic converter? It could be plugged and the factory exhaust system is restrictive, even with converter removed. If the motor is tired, it needs rebuilt with different pistons. If it has good compression and oil pressure, early 350 heads milled to 64cc and a better cam with dual exhaust will help a lot. A 2000+ stall should also be installed. We are spoiled with new cars. My similar weight Dodge Challenger GT with nearly double the HP, 305, nearly same torque 268 ft/lbs, a 4.71 to 1 first gear and 3.09 final gear ratios is like a Rocket ship in comparison, pardon the pun. Good luck.
Old Dec 5, 2021 | 03:24 AM
Tri-Carb's Avatar
Here is your cheapest path to significantly more performance:
Olds 455 complete engine $800 - ClassicOldsmobile.com
Old Dec 5, 2021 | 07:13 AM
As said above, there's not really much you can do engine-wise to increase power without doing some major work.
Does the car still have the factory exhaust system? If so, that is a very restrictive system, so installing a true dual exhaust system would help the engine breathe.
Other than that, as said lower rear gears are the best bang-for-the-buck. Get rid of the 2.56:1 gears and install anything in the 3.xx:1 range and it will feel like you have a huge increase in engine power. Your 8.5" 10 bolt rear has lots of aftermarket support so parts are readily available.
Old Dec 5, 2021 | 07:31 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Start with a good tuneup and a nice set of true dual exhaust.
Old Dec 5, 2021 | 11:15 AM
Agreed. I neglected to mention above that the OEM catalytic converter in that era was extremely restrictive. If you must retain the cat converter, the modern versions flow a whole lot better.
Old Dec 5, 2021 | 11:37 AM
69CSHC's Avatar
Michael all advice already given just about covers it. But a clearer picture of your cars current state would definitely help us understand your level of disappointment.
You say low mileage but is she bone stock ? Is she already dual exhaust and she still feels like a dog to you ?
Your cars stock rear is the biggest culprit in lack of oomph. The mid to late 70s era was overweight and underpowered, then to add insult to injury they installed numerically low rear gear ratios to maximize mileage. The results were devastating across the board. Mileage was not enough to justify the fact that the cars couldn't get out of their own way.
Old Dec 5, 2021 | 11:54 AM
Tuffnut's Avatar
As previous posters have mentioned. Right on the money. My 75 cutlas 350 was gutless. No longer. 2.56 gears changed 3.42. Huge change. 2004r tranny. #5 heads. Cam /intake and new duals. New pistons shallow dish. Thornton jr manifolds. You will have carb work to on the lean jets. It will actual burn some good rubber now. Good luck.
Old Dec 14, 2021 | 04:59 PM
69CSHC's Avatar
Fantastic! You have a great recipe. The ideal gear, transmission, and heads. Along with a cam that's more aggressive than the 350 stick cam. (Lunati,10420701... intake duration duration 213, exhaust 219.) Essentially the exact way I think I should go if and when I ever decide to get my 350 to be all it can be within reason.
I am figuring you may have 100 HP over stock, when you consider all modifications made and the fine tuning it took to make the engine sing. Now you have a good-looking ride that runs like it always should have. Appreciate your photo album as well. Including the layout of parts and clean finished product.
Old Dec 17, 2021 | 11:40 AM
michael l's Avatar
would i see decent improvement by putting #7 heads on my 75 cutlass 350?
Old Dec 17, 2021 | 12:30 PM
Tri-Carb's Avatar
A rule of thumb might be a gain of 3-4% horsepower for every additional point of compression added while keeping everything else the same.
Old Dec 17, 2021 | 01:15 PM
There is a difference in combustion chamber volume between your #8 heads and the #7 heads (~80cc vs ~68-70cc). So installing the #7 heads without any other changes would raise the compression almost 1 point.
Old Dec 17, 2021 | 02:59 PM
Your current #8 heads are probably closer to 77 or 78cc. I measured two sets that came off motors with shim head gaskets. So it probably will be almost exactly 10cc. The problem is the difference in head gasket thickness. The usual Felpro replacement are .042" compressed vs the factory .017" compressed shim head gaskets. You only gain about a 1/2 point without cutting the #7 heads. The other gain is the exhaust side flow. A bowl cutter is needed for your current #8 to flow was well. The numbers out there are about a 40 cfm on the exhaust side, similar on the intake side. Also stock pistons are around .025" below deck. I use this compression calculator, the regular part anyways.
https://uempistons.com/p-27-compress...alculator.html
JAYDOG1984
May 23, 2021 08:38 AM
banny
Jul 5, 2018 06:26 PM
Btodd34
Aug 31, 2014 08:27 AM
thebarrowgang
Dec 11, 2008 07:26 PM
cmblair76
Cars Wanted
Sep 20, 2008 09:24 AM
