70,350
Old Dec 20, 2021 | 12:12 PM
65-330's Avatar
70,350
Need some help. A local guy here has a 350 from a 79 cutlass. 60 over, what do you think about this? Rebuilt about 5 yrs ago. Has it for sale for 800, just needs to be put together. He does not really know much about it.
Old Dec 20, 2021 | 12:46 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That looks like a low compression, cast piston build. It does have the upgraded double roller timing set on it. What do the pistons have stamped on them? The 3A heads flow terrible and are crack prone. Plus that is a later windowed main block. It is worth a few hundred as is, offer him $500.
Old Dec 20, 2021 | 12:47 PM
65-330's Avatar
332ap .040
Old Dec 20, 2021 | 12:50 PM
65-330's Avatar
Your probably right! Could I use the lower end and get better heads?
OLDSter Ralph's Avatar
You have long block that was rebuilt by someone else. Is it a 1970 or a 1979 ? If its .060" over, how come there are .040" pistons in it. Do you know that you have all the parts needed ? Do you know that you have all the bolts needed ? Where are the gaskets you need ? Who will finish assembling all the pieces ?
I wouldn't give what he wants, especially when its still a basket case. I would say its worth about 1/2 what he is asking.
Old Dec 20, 2021 | 12:51 PM
Yeah, those are probably a 24cc dish cast piston. Bring a digital caliper and measure how much the pistons are below deck, probably quite a bit. I could have got a pair of the later 350's for $100 each, I passed on them.
Old Dec 20, 2021 | 12:52 PM
65-330's Avatar
Oldster, 79, I couldn't change it from 70, yes I looked at the pic and saw it was 40. Like I said, he doesn't know much about it, plus I am still learning as well. There is another pic that I did not post with a box of all parts
Old Dec 20, 2021 | 01:00 PM
69CSHC's Avatar
My gut instinct is pass.
Its definitely a late 70s block, which are the last 350s you want to build up.
Old Dec 20, 2021 | 01:02 PM
65-330's Avatar
Yea, thats what I was thinking,69cshc, thanks all, Ill look for something better.
Old Dec 20, 2021 | 01:15 PM
Yes, those are the HUGE 24cc dish pistons, and they are short on compression height as well (1.596").
Old Dec 20, 2021 | 01:45 PM
Windowed mains, soup bowl pistons, and 3A heads with crappy ports. Not my first choice.
Old Dec 20, 2021 | 02:39 PM
coppercutlass's Avatar
Chevy budget Olds powered
I would walk.
Old Dec 20, 2021 | 02:49 PM
cutlassefi's Avatar
Don’t forget, a regular cast crank as well.
Old Dec 20, 2021 | 03:16 PM
RetroRanger's Avatar
72 Olds CS
Roller tipped rockers
Old Dec 20, 2021 | 03:45 PM
Good eye on the roller tip rocker arms. It probably has an upgraded cam. It could be honed to fit the 10cc Mahle dish forged pistons for around 9 to 1, if the block is fresh enough. Again more money in the least desirable 350.
Old Dec 21, 2021 | 03:41 AM
Dynoking's Avatar
That engine is not "rebuilt". From the pictures provided the best I can tell is replacement pistons were installed. Deck appears to have been cleaned up with an abrasive, ditto with intake side of cylinder heads. Can not tell if heads were milled, valves appear to have reused. Missing rod nut? On a "rebuild"? My opinion; this is a bucket of parts, I would pass.
Nov 9, 2021 09:46 AM
spgosselin
Jun 6, 2020 05:39 PM
BOOWAH
Oct 17, 2017 11:11 AM
j808702
Oct 31, 2016 07:50 PM
