'73, 350
'73, 350
Hello,
I've just taken possession of my '73 Delta 88, has a small block 350,
I'm probably going to have many questions down the track, but first off,
noticed the dip stick sleeve is loose from the block, bit of a bugger of a
spot to get to, haven't investigated fully, looks like its meant to lock in
somehow with a bump & recess type setup, anyone had this happen,
regards, Cus
regards, Cus
They are just stuck in the block.
I have had them come a little loose
before. If they aren't broken at the block
a few love taps on top of the tube with
a piece of hardwood to soften the blow
should get you fixed up. Good luck, welcome
and post a few pics of your car when you get a chance.
Well, fired it up on the weekend after oil & filter change, new plugs etc.,
runs really well, very quiet & smooth, still haven't got to the brakes, so just
static running. Generator light coming on though, put the meter on it,
was returning about 12.8v, (at idle) is that enough?
regards, Cus
regards, Cus
