73 350 4bl
Old July 17th, 2013, 05:45 AM
trevor s's Avatar
73 350 4bl
My 73 was owned by an old lady. Thecar has 72,800 miles on it andis in excellent shape just needs paint and brakes but the 350 could use a kick in the pants. It runs perfect with no noise, abnormal smoking etc.
I was thinking 72 7a heads edelbrock performer cam and llifter kit performer 3711 intake, rebuild the q jet and a set of headers. Any thoughts on the 7a heads? any problems I may have.
trevor s is offline
Old July 17th, 2013, 06:26 AM
Welcome, we do like pictures. That should be a good combo for an out of the box improvement. Most Olds heads flow the pretty close with a bit of messaging.
oldcutlass is online now
Old July 17th, 2013, 06:35 AM
trevor s's Avatar
7a heads
would it make sense to replace the heads or spend some money at the machine shop with the #8 heads? Thanks!
trevor s is offline
Old July 17th, 2013, 07:01 AM
cutlassefi's Avatar
Do the 7a's and there are better cams out there than that generic Edelbrock.
cutlassefi is offline
Old July 17th, 2013, 12:48 PM
Chevy budget Olds powered
coppercutlass's Avatar
I ran a 73 shortblock with 72 7a heads. Compression was 9 to 1 . I ran a comp 260h cam. With an edelbrock intake and 60o cfm carb, full length headers, hei dist. X pipe exhaust, 2300 stall and 3.73 gears I got it to run 13.86 when the car was all steel still. 13.71 w fiberglass fenders and hood.
coppercutlass is offline
Old July 17th, 2013, 02:40 PM
trevor s's Avatar
thanks! for rear gears what ratio could / should I use. Right now they are 2:56 or 2:73's? I don't plan on racing it so I'm not so worried about a posi and I was going to keep the original th350
trevor s is offline
Old July 17th, 2013, 03:33 PM
cutlassefi's Avatar
3.42 seems to be a good combo for a mild small block.
Old July 17th, 2013, 04:41 PM
trevor s's Avatar
so a 3:42 will fit the stock carrier. am I right in thinking it's a 2 series???
trevor s is offline
Old July 17th, 2013, 04:59 PM
Yes, and if you may consider going to a Performer RPM manifold depending on your cam choice.
Old July 18th, 2013, 11:18 AM
Olds1971's Avatar
What all motor work did you have to do as far was boreing it, lifts/rockers ect?
Olds1971 is offline
Old July 18th, 2013, 12:11 PM
Short block was std. Bore freshened up. Heads where freshened up. Both great cores . Rockers where stockers. Nothing fancy just the proper set up and matching of parts . I also ran manual steering to free up hp. The car went from 14.0 to 13.86 with the addition of an x pipe. It was a solid 14.0 car up until I added the x pipe.
Old July 18th, 2013, 12:20 PM
Olds1971's Avatar
Not to high jack this thread but copper maybe you can give me advice. I have a stock 72 olds 350 in a four dr 83 it runs 10.8 at the eighth hoping to break low 9 is it possible with a stock block with no boreing ect
Olds1971 is offline
Old July 18th, 2013, 12:40 PM
1970-W30's Avatar
I don't believe the 3.42s will work on the 2.56 or 2.73 carrier. It will require a different carrier, or a spacer ring.
1970-W30 is offline
Old July 18th, 2013, 12:44 PM
The key to my combo was the 73 shortblock with 72 heads since the 73 block has a smaller cc dish with a shim gasket the compression is right around 9 to 1.
Old July 18th, 2013, 01:12 PM
Olds1971's Avatar
Whats the compression on a 1972s?
Olds1971 is offline
Old July 18th, 2013, 01:16 PM
I think it was advertised 8.5 to 1 but closer to 8 to 1.
Old July 18th, 2013, 01:19 PM
Olds1971's Avatar
how to you change compression? Would it make much improvement going from 8:1 to 9 ;1
Olds1971 is offline
Old July 18th, 2013, 02:02 PM
DoubleV's Avatar
Better pistons, decking block, milling heads, thinner head gaskets or any combination of those things.
Not much, but the higher CR opens up the door for a bigger/better cam which would then make a noticable difference over the weak stock cam.
DoubleV is offline
Old July 18th, 2013, 04:02 PM
Olds1971's Avatar
Can you do a couple of those or all to change compression?
Olds1971 is offline
Old July 18th, 2013, 04:34 PM
It comes down to many variables like head cc, piston dish cc if it has one, how far in the cylinders they sit at tdc, head gasket thickness. If you are planning a build knowing what cam will work with the mods you are planning to make or are already running will determin what you will need to do to have the engine run properly.
Katman
Tech Editor's Desk
May 18th, 2015 06:16 PM
f-85
July 28th, 2012 05:13 PM
D Appeldorn
March 4th, 2012 02:42 PM
Seff
June 14th, 2011 01:20 AM
chevyman
January 30th, 2011 12:10 PM
Quick Reply: 73 350 4bl
