‘72 Olds 350 Cylinder Pressure Specs
Old Aug 4, 2019 | 04:26 PM
Roqetman's Avatar
Can someone tell me what the normal psi range is for a stock ‘72 350? Or, where can I find this information?
Thanks!
Old Aug 4, 2019 | 07:44 PM
I have an original numbers matching '71 stock sbo 350 w/ 120K miles new intake manifold gasket & new oil pump, screen and oil pan gasket. Here are my numbers (below). Based only upon my limited reading and perusing of this site and others, I believe the number would fall somewhere between 135psi - 165psi? Just a SWAG.
Old Aug 4, 2019 | 08:52 PM
jaunty75's Avatar
It's on page 6C-3 of the 1972 Olds Chassis Service Manual. You DO have this reference, don't you?
It's actually quite general. All cylinders should be at least 100 psi, and the lowest-reading cylinder should not be less than 70% of the highest-reading cylinder.
Old Aug 5, 2019 | 04:55 AM
Dave26's Avatar
I recently sold a completely stock 350 out of a '72 with 100,000+ miles. Before I sold it I also did the wed/dry compression test and had numbers almost exactly the same as Norm's.
Old Aug 5, 2019 | 06:49 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have also found a couple of 76 motors in great shape 140 to 142 psi on my current one when had #8 heads and the 204/214 cam, same 8 to 1 compression . Oil pressure is another big sign of engine health, throw a gauge on it. The above, plus my personal experiences are why I love the Olds 350 so much. Try grabbing a brand "C" motor from that era, really just about any other brand. At minimum it will have either a flat cam or had it replaced. The only thing that usually needs replaced is the nylon coated cam gear. Many other brands also thought it was a bright idea, it was not.
garage goat 67
Nov 8, 2016 08:48 AM
kjr442
Feb 23, 2015 11:09 AM
Finn5033
Dec 17, 2012 08:52 AM
knighthawk
Apr 2, 2011 08:47 AM
import extermination
Jun 26, 2010 06:07 PM
