'72 air cleaner
'72 air cleaner
I have seen several '72 air cleaners on Ebay. The round part that fits over the carb is a perfect circle. The '73 air cleaner that is on ny '72 Q-jet has a notch in the front that fits over corresponding part on the carb. I guess the ones on Ebay are for 2 barrel carbs? I know they would not fit without that notch. Chumley
So the ones without the notch are for engines that did not have the thermostatic controlled air cleaners? My '70 had one, and I thought they were pretty much standard equipment since then.(on taking a second look at mine with the notch, I guess the one without a notch would fit, although it would not be "locked" into place.) Would there really be that much movement if the lid screw were tight enough?
Chumley
Chumley
No. What I was trying to say is that as the 70s went on and there was more "stuff" that connected to the air cleaner, it was more important for the air cleaner to be positively located in a specific orientation. The incorporation of HEI distributors in 1973 was probably the event that triggered the notch for clocking, since many of these air cleaners needed a clearance "dent" on the underside to clear the larger distributor cap.
69CutlassAlex
December 2nd, 2011 08:01 AM
WTony
July 3rd, 2010 11:12 AM
StickW31
February 25th, 2010 01:14 PM
