'72 7A head volume
Old October 18th, 2011, 07:21 PM
Where were you in '72?
boondocker's Avatar
'72 7A head volume
What is the actual head volume for 7A heads?...I'm getting a lot of different opinions off the web. I'm finding my new build is very sensitive to octane and according to my calc's my compression is 10.92 (too much for the cam I'm running).
Bore = 4.087
Stroke = 3.385
gasket compressed = .040
head volume = 69
deck = .020
...and flat tops
boondocker is offline
Old October 18th, 2011, 07:45 PM
I think that it varies enough, especially if you had any work done, such as valves or seats, that you've really got to measure it to be sure.
MDchanic is offline
Old October 19th, 2011, 04:29 AM
boondocker's Avatar
The heads were redone, 3 angle, new seals, 5thou cleanup etc...
I mistyped on the calculator, head gasket diameter...estimated compression is now 9.88. I live in a small town outside of the city and the expensive gas here tends to sit, which I suspect effects it's quality. The exhaust pops when the air filter is on, when off it runs fine. If I get my higher octane gas from the more travelled gas stations, the engine runs great with the air filter on or off (I've confirmed this on many fill ups).
Old October 19th, 2011, 05:01 AM
cutlassefi's Avatar
Bore = 4.087
Stroke = 3.385
head volume = 69
deck = .020
...and flat tops
What cam are you running?
cutlassefi is offline
Old October 19th, 2011, 06:07 AM
boondocker's Avatar
comp XE262
Old October 19th, 2011, 06:11 AM
Tony72Cutlass'S''s Avatar
The tech section on 64-90 heads says that they are 64cc. But i do agree with eric, Unless you have a bone stock engine, i'm sure it has changed a little.
Tony72Cutlass'S' is offline
Old October 19th, 2011, 06:20 AM
bigD's Avatar
it's my understanding that the big block heads tend to be a larger cc than rated, i don't know if this holds true for the small blocks as well.
have you tried any fuel additives with the lower octane gas? maybe a can of seafoam or marvel mystery oil with each fill up will cure what ails ya? small price to pay...
bigD is offline
Old October 19th, 2011, 06:29 AM
For what it's worth, I dumped that rislone ZDDP stuff into my crankcase to "apparently" make my oil better suited for flat tappet camshafts.
But Seriously, my lifters stopped ticking, engine sounds better.
maybe It's just me, or maybe my car just badly needed an oil change. But for 7 bucks a can i'll take the hit.
Old October 19th, 2011, 07:52 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Stop into your local paint store (not big chains like home depoo)
Sherwin Williams is a good place to go, but an auto paint supply house would be best and cheapest.
You can pick up a 5 gallon bucket of toluene for around 20-30 bucks. It's 114 octane by itself.
Mixing at a 10:1 ratio gets you 2 extra points of octane.
89 octane X 10 gallons= 890
114oct X 1gal= 114
890 + 114 = 1004
1004 points ÷ 11 gallons = 91.272... octane
J-(Chicago) is offline
Old October 19th, 2011, 08:02 AM
boondocker's Avatar
114oct X 1gal= 114
890 + 114 = 1004
This is a solvent, right? Is this commonly used as an octane booster? This would be a lot cheaper than the extra .10-.15 per litre I pay over 87 Octane.
Old October 19th, 2011, 08:33 AM
1974 DELTA 88
AZ455's Avatar
Why not just buy an oil that contains ZDDP already and use it every oil change? How much does the Rislone ZDDP add to ~5 qts?
Shell Rotella T 15w-40 oil is 1200 ppm ZDDP. You may get more out of the additive, don't know.
Edit: According to page two of http://www.barsproducts.com/tech/4401_tech.pdf you will get a bit more ZDDP from the additive than the Shell oil.
AZ455 is offline
Old October 19th, 2011, 08:35 AM
Correct. Toluene is one of the ingredients in gasoline that gives it's octane points.
You're basically just putting an extra shot of rum in your cola for a better "effect".
Just be aware, that it takes away cylinder wall lubrication as a trade off, so don't go crazy with it. A lot of race cars used to run just toluene, but they got rebuilds every other race.
Old October 19th, 2011, 08:59 AM
Or you could check the status of the IOGEN corporation in your Canadian backyard, and eventually go to an e-85 conversion. They're putting a huge effort into E-85 up by your neck of the woods.
Old October 19th, 2011, 09:04 AM
boondocker's Avatar
yeah i know, i'm surrounded by cornfields.
Old October 19th, 2011, 09:13 AM
What, you're afraid that something on the web might not be correct?
All the published numbers trace back to the factory and/or NHRA blueprint numbers. The as-cast volume of ANY head will just about always be larger than the blueprint number to allow for resurfacing.
joe_padavano is offline
Old October 19th, 2011, 09:21 AM
Cool! I'm not sure if we get shell rotella oil up in these parts. When i go to the hardware/auto store, the rislone stuff is all i could find.. Figured it would be better than nothing.
What does the shell oil cost per gallon?
Old October 19th, 2011, 11:00 AM
yankees's Avatar
Head Volumes
NHRA.com has all of those specs for the #409147 7A heads
Intake Volume CCs = 153
Exhaust Volume CCs = 138
yankees is offline
Old October 19th, 2011, 11:10 AM
Vega's Avatar
Originally Posted by j-(chicago)
or you could check the status of the iogen corporation in your canadian backyard, and eventually go to an e-85 conversion. They're putting a huge effort into e-85 up by your neck of the woods.
Cold starts are worse though, not a big problem where im at but in canada i could see it getting annoying
Vega is offline
Old October 19th, 2011, 12:17 PM
And yet, neither of those numbers is the combustion chamber volume, which is what the OP asked about.
Old October 19th, 2011, 12:50 PM
yankees's Avatar
7A Heads
64 CCs according to 442.com and the factory can be anywhere from + or - 2ccs. At least that is what we find on our BBC closed chamber heads 106-109cc
It's a simple measurement at any machine shop or at home. Buret, Vasoline and a flat piece of clear plastic. Don't forget you valves and spark plug.
yankees is offline
Old October 19th, 2011, 01:01 PM
cutlassefi's Avatar
68cc is more the norm. And that XE262 is too small for almost 10.0:1
Old October 19th, 2011, 01:05 PM
Vega's Avatar
what might a good comparable cam be for that compression? And does SBO and BBO make a difference on cam choice? (for example, slightly larger cams for BBO slightly smaller for SBO) Im thinking something in the mid-270s
Vega is offline
Old October 19th, 2011, 03:02 PM
Warhead's Avatar
The blueprint spec is for NHRA stock class specs, and has nothing to do with what was installed on vehicles. This is the minimum cc's allowable by NHRA inspection in tear down, when they verify a car is within "the rules".
All #5, #6, #7, and 7a heads will be around 68cc's from the factory.
Throw in valves, and seats being cut, thicker gaskets and it will take more than a .005 cut to get it back to what the factory made it.
Jim
Warhead is offline
Old October 19th, 2011, 04:00 PM
Chevy budget Olds powered
coppercutlass's Avatar
now im not sure on this one but cant you run a thicker gasket if that's the desired cam you want i know they make gaskets thicker than .040 but price might be a tad bit more
coppercutlass is offline
Old October 19th, 2011, 04:17 PM
cutlassefi's Avatar
[QUOTE=Vega;333196]what might a good comparable cam be for that compression? I'd do something around a 220/228 at .050 depending on gear etc. And does SBO and BBO make a difference on cam choice? (for example, slightly larger cams for BBO slightly smaller for SBO) Yes, but also 350 vs 403 or 400 vs 455. Im thinking something in the mid-270s. That's only part of it. The at .050, intake centerline and lobe sep also matter as well.
Old October 19th, 2011, 04:59 PM
Vega's Avatar
True. I was just going for a general size as its easier to match size with compression and then you can go in and work the specifics to your valvetrain and all
I would think 10.9 would be too much compression for street gas. Idk maybe gasoline in Canada is different than in the US. I was planning to run 10.5 and ive even 2nd guessed myself on that thinking it might be too high for pump gas
Vega is offline
Old October 19th, 2011, 06:46 PM
cutlassefi's Avatar
Marginal with aluminum heads, no way with iron.
<wdd>
October 20th, 2016 05:06 PM
1971
October 28th, 2011 11:20 AM
geckonz08
June 10th, 2010 11:46 PM
Joel n
January 12th, 2007 03:34 PM
72RocketPower
February 9th, 2006 07:46 PM
Quick Reply: '72 7A head volume
