7111 Intake won't fit - Milling required?
Old Aug 7, 2011 | 05:53 PM
dsolomon's Avatar
I am rebuilding a 1970 350 and am unable to get the 7111 Edelbrock intake to fit. Here is my assumption, tell me if I am correct
I didn't do the work on the heads, they were done by the previous owner. The heads had been milled but cc'd at around 64cc. I suspect that they were just dusted to ensure flatness. To bump the compression a bit I installed Fitzgerald (stock) steel shim gaskets with a compressed thickness of .019".
I can just get the bolts in if I leave out the turkey pan but with it in there I can't get both sides to start.
I am betting that Edelbrock designed thier intakes with an aftermarket .045 compressed thickness gasket in mind. The reduction of .025 from the thinner gasket and whatever was milled off the heads is my problem.
What do you think?
Old Aug 7, 2011 | 08:24 PM
coppercutlass's Avatar
Chevy budget Olds powered
you will need to mill the intake i had to do the same to mine i have the heads milled .024 and i didnt even come close
Old Aug 8, 2011 | 04:32 AM
dsolomon's Avatar
Were you using steel shim gaskets of the thicker aftermarket style?
Joel
Apr 26, 2017 01:37 PM
boese1978
Feb 27, 2013 07:36 PM
arodenhiser
Nov 30, 2012 06:25 AM
Kidcutty
Mar 25, 2010 09:29 PM
