71 Cutlass Engine Swap
Old May 4, 2013 | 10:00 AM
CutlassSupreme72's Avatar
Hi guys, Im looking to put something a little newer and bigger in my 71 Cutlass Supreme. Is there any new motors that that I could drop in without to much modification?
Old May 4, 2013 | 10:07 AM
I don't understand your question? Any Olds motor will drop in.
Old May 4, 2013 | 10:20 AM
Also, any motors newer than '71 will have lower compression and performance.
Usually with a '71, you want to drop in an older motor.
Old May 4, 2013 | 10:45 AM
The thing is, I was looking to pull the motor out of a newer(2008+) Corvette or Camaro with a computer. But I didnt know if GM had changed the mounts. It would be easyer to maintain and find parts for.
Old May 4, 2013 | 10:51 AM
garys 68's Avatar
I used an L59 (iron block LSx motor), but same thing applies to the aluminum blocks.
https://classicoldsmobile.com/forums...-iii-swap.html
Old May 4, 2013 | 10:57 AM
This needs to be moved to the Non-Olds-Powered section before all hell breaks loose.
Old May 4, 2013 | 11:01 AM
I don't know about the easier to maintain part, and there are no issues in getting parts to any older Olds engine or most engines from 60's thru the 70's. Most of us like the older cars for the simplicity and ease of maintenance, no computers, sensors,...etc.
There are a great number of threads regarding the LS swaps in the non-olds powered section. From what I understand they are not too problematic depending on trans choice.
Old Mar 19, 2023 | 03:36 PM
CutLS's Avatar
I swapped an LS1/4L60E into my '72 Cutlass S. A few road bumps but otherwise its very straight forward.
Old Mar 20, 2023 | 06:53 AM
Only a decade after the original post...
Old Mar 20, 2023 | 08:00 AM
redoldsman's Avatar
Proud Viet Nam Veteran
And the OP hasn't posted here in ten years and only ever made two posts.
805cut
May 3, 2012 08:11 PM
'69CutlassVert'
Aug 25, 2011 07:19 AM
oldsmobum
Jan 14, 2011 10:10 PM
<jimmy>
Nov 18, 2007 02:09 PM
Dread
Mar 16, 2007 12:18 PM
