71 350 rebuild
Old Jun 15, 2021 | 05:01 AM
1971w25's Avatar
71 350 rebuild
Hi all,
. So I am going through my 350. New flat top speed pro pistons, felpro head gaskets. Should I be worried about the valve train ,intake manifold with the thicker head gasket? Thanks
Old Jun 15, 2021 | 05:29 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I would assume the machine shop milled the heads and decked the block, look at the paperwork. Those two might make up half of the thickness of the new head gaskets. What cam are you using?
Old Jun 15, 2021 | 09:20 PM
1971w25's Avatar
Cam
The Edelbrock.
Old Jun 15, 2021 | 10:05 PM
That is a mild cam for 10+ to 1 compression. I hope you have 93 octane, a proper tune on the carb and a conservative timing curve. I ran 9.6 to 1 with that same cam, slightly worse quench with 91, it was finicky. I needed very cold plugs and very conservative timing.
Old Jun 17, 2021 | 11:19 PM
1971w25's Avatar
Thanks for the help. I have not bought the cam yet. Was waiting to see final results not the machine work and the actual compression ratio. Recommendations?I have headers,stock qjet, 2.56 gear ☹️
Old Jun 18, 2021 | 05:55 AM
That 2.56 gear is the issue, you want high cam duration or very high stall converter will be needed. I have 2.78 gears for now but will be moving tob 3.90 with a 2004R OD. I am going with the Mahle 4.100" 10cc dish pistons. With my #6 heads that measured 62 to 64-65cc. I am polishing one heads chambers, since it was cut twice due to a nick during transport by the original owner of these heads. Even with both heads at 65cc, I will be right around 9.6 to 1. Mark Remmel (Cutlassefi) had a 218/218 roller cam that should work with my build. It will be tuned with a wideband and the timing curve dialed in. Can you get the 6cc dish Speedpro forged pistons if it is already bored and honed? You would have to see the Mahle pistons availability if it isn't finished honed. What octane do you have locally? Also upgrade your torque converter, the factory 1600 stall will make your car a dog, I have been down that road. You want something that is 2000+ stall. The Jegs 2300 stall is an affordable, decent replacement. Good luck.
Old Jun 18, 2021 | 01:11 PM
brownbomber77's Avatar
Fix the gear first. I like using the back to front philosophy. Start with the running gear and then move to the engine. Change the rear axle, then a shift kit or something else that can help manage the power, then a converter, then exhaust such as long tubes, then intake, roller rockers, camshaft, and finally, heads. Cam won't do a lot of good if the air can't get in or out.
Greg Rogers
Aug 9, 2020 04:00 AM
cruisin72
Dec 27, 2018 09:56 AM
simonb.
Jul 13, 2014 04:27 AM
my71olds
Aug 14, 2013 05:49 PM
deltathunder
Jul 21, 2008 08:10 PM
