371 rocker replacement.
Old Jun 18, 2021 | 07:54 PM
Cdonze's Avatar
I inherited a 57 Super 88 371 J2. Engine recently rebuilt but apparently used original rockers. Has new hydraulic lifters. Has valve lifter tapping noise on passenger side. Pulled valve cover and found slop in front cylinder intake and exhaust valves. All others tight with no lash. Pulled rockers and found both worn badly where on push rod side (pic attached). All push rods look good.
my questions are...
1) Should I just replace the 2 bad rockers?
2) Replace 2 bad rockers and push rods?
3) Replace all rockers and push rods?
2 worn rockers at top of photo. All others look good like the bottom one in the photo.
Old Jun 19, 2021 | 08:58 AM
Charlie Jones's Avatar
Phantom Phixer
Choice # 3 .
If two rockers are worn that badly , then the rest are well on their way to being worn out .
Rocker shafts should be replaced in conjunction with an overhaul anyway , because they trap sludge .
boese1978
Jul 22, 2017 04:12 PM
RROLDSX
Dec 12, 2016 09:01 PM
Macadoo
Mar 1, 2015 01:01 PM
67Olds442X2
May 13, 2011 05:18 PM
70special
Sep 28, 2010 07:33 PM
