70 350 - Where to put temp sensor for fans ??
Old Sep 29, 2010 | 10:35 PM
Aceshigh's Avatar
Is there a place on the 1970 Olds 350 heads for a sensor to go ??
I'm not at home right now to check.....just curious if the manifold is the only place to hook up a temp sensor / switch.
I know on the Chevies between the #1 & #3 cylinder there is as well #6 and #8. But it doesn't look like it can be done on these Olds motors. I know I can put them in the manifold, but looking to see if it's the only option or if the heads have a spot.
Old Sep 30, 2010 | 07:00 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Intake manifold.
Old Sep 30, 2010 | 07:56 AM
Some early Toronados had head bolts with a temp sensor in them. Of course, the normal sender in the intake coolant crossover will be a lot easier.
Old Sep 30, 2010 | 10:09 AM
svnt442's Avatar
There are no plugs to remove in the heads for a temp sensor on Olds engines.
Old Oct 1, 2010 | 10:35 AM
Aceshigh's Avatar
Thanks guys.
Oh well, I was hoping to keep it out of view. The sensor I got from Glowshift
gauges really sucks then because it's not registering the temps properly.
It's not brass, it's some kind of chromed metal......looks cheap.
I'll have to put in a different temp sensor then.
84hurst
Jul 16, 2012 07:56 AM
54oldz
Jun 20, 2012 07:13 PM
scott_442
Feb 22, 2011 05:26 AM
chris83
Jun 13, 2009 08:16 PM
cormike
Aurora
Jan 4, 2009 07:30 AM
