70’ 350 A/C Bracket Alternatives
Old April 26th, 2018, 12:34 PM
tgilligan's Avatar
Hi All,
Are there aftermarket or alternative brackets I can use in place of the stock bracket for the A/C that goes from under the head to the top of the manifold? Had to shave a bit of my current bracket to fit my dual line feed to my Holley and leave room for my fuel gauge. Looking to see if there was a cleaner alternative from the bulky bracket.
tgilligan is offline
Old April 26th, 2018, 02:48 PM
The only aftermarket brackets are those designed to hold the smaller Sanden compressor. I have one from Classic Auto Air that works very well.
Of course, you COULD just change the carb inlet plumbing...
joe_padavano is online now
Old April 28th, 2018, 02:50 PM
442Classic's Avatar
Look at using one off a 75 or newer Olds it is less of a boat anchor, I used all the pieces off of a 75 other than the alternator piece on my 71 442 when I installed my aftermarket AC kit.
442Classic is offline
LeadFred
Brakes/Hydraulic Systems
October 5th, 2016 12:50 PM
StickW31
September 13th, 2012 07:12 AM
ChefDeadpool
Body work
November 21st, 2011 07:48 PM
xerxes600rr
August 30th, 2011 06:43 AM
Quick Reply: 70’ 350 A/C Bracket Alternatives
