70’ 350 A/C Bracket Alternatives
Old Apr 26, 2018 | 12:34 PM
tgilligan's Avatar
Hi All,
Are there aftermarket or alternative brackets I can use in place of the stock bracket for the A/C that goes from under the head to the top of the manifold? Had to shave a bit of my current bracket to fit my dual line feed to my Holley and leave room for my fuel gauge. Looking to see if there was a cleaner alternative from the bulky bracket.
Old Apr 26, 2018 | 02:48 PM
The only aftermarket brackets are those designed to hold the smaller Sanden compressor. I have one from Classic Auto Air that works very well.
Of course, you COULD just change the carb inlet plumbing...
Old Apr 28, 2018 | 02:50 PM
442Classic's Avatar
Look at using one off a 75 or newer Olds it is less of a boat anchor, I used all the pieces off of a 75 other than the alternator piece on my 71 442 when I installed my aftermarket AC kit.
LeadFred
Brakes/Hydraulic Systems
Oct 5, 2016 12:50 PM
StickW31
Sep 13, 2012 07:12 AM
ChefDeadpool
Body work
Nov 21, 2011 07:48 PM
xerxes600rr
Aug 30, 2011 06:43 AM
