'69 Cutlass 350 Upgrade
Old Sep 10, 2020 | 11:45 AM
dccutlass's Avatar
Currently in the process of restoring my father’s ‘69 Cutlass S convertible. Pulled the engine with 130,000 miles & sent it off to the machine shop for evaluation. Block needs 0.030” bore so new pistons are in order. However the aftermarket availability for this is limited & will require custom parts. Looking to warmup the 250 HP engine with some higher compression pistons but retain the stock heads. Car is just a cruiser with TH350 trans & 2.73 gears fueled by a Q-jet & a new Erson cam,E540121, 214 duration & 0.478 lift. Real question is what will be the octane requirement if I go with 10.5 CR? Or should I dish the pistons to get 10.25? Want to be able to run on pump grade premium.
Old Sep 10, 2020 | 12:37 PM
It's good that you are asking about the pistons as the common aftermarket replacement cast pistons have HUGE 24cc dishes that result in around 7:1 compression ratio, so avoid those at all costs. There are multiple forged pistons available; you just need to determine what compression ratio you want.
FYI, flat top pistons such as the SpeedPro L2320F (10.5:1 replacement pistons) along with Fel Pro head gaskets, no block deck milling, and typical heads with ~68cc combustion chambers will give around 9.8:1 compression ratio. If you use the L2321F with 6cc dishes (10.25:1 replacement pistons), you'll get around 9.2:1 compression ratio.
Old Sep 10, 2020 | 12:39 PM
cutlassefi's Avatar
Use the Mahle Motorsport pistons. They’re available in 4.065, 4.100 and 4.155 sizes. With a stock head you’ll get about 9.25-9.5:1 compression.
You may also want to add an RPM Intake. It’ll accept the Qjet and offer a performance advantage.
timrocket72
Mar 4, 2020 02:09 PM
Doug Carner
Jan 15, 2020 07:39 AM
455man
Mar 5, 2017 10:00 AM
heavy D
Dec 28, 2013 05:30 PM
aussiemobile
Dec 8, 2009 02:55 PM
