69 350 Rocket running hot, maybe lean?
Old August 21st, 2012 | 11:00 AM
Supreme78's Avatar
My 78 cutlass with a 69350 is runnin really hot, I think I got it figured out last night by running dual electric fans... And then pulled a plug and realized it was a white-ish color, not the brown I would like to have seen. I just advanced my timing, so is that just a issue of me messing with the carb to adjust? It's a 4 barrel edelbrock, 650(600?) cfm. Has two screws on the front so im not sure which side is which. Seems to be lacking in power also, but the timing helped it... Just is runnin a little lean for my liking. Suggestions?
Old August 21st, 2012 | 11:05 AM
Supreme78's Avatar
Really hot meaning like 240-260 degrees.
Old August 21st, 2012 | 11:15 AM
You have a major cooling issue with those temps!
Old August 21st, 2012 | 11:29 AM
Supreme78's Avatar
Oh yeah. It's burning up lol. But it's running colder now. How would I go about richening the mix? I know dirtbike carbs but these car ones... Lol
Old August 21st, 2012 | 11:52 AM
First off, you got your cooling issue corrected? What are your current tuneup specs? What distributor are you running? Is the engine stock?
Old August 21st, 2012 | 01:00 PM
Supreme78's Avatar
I think. I ran out of gas on the test drive last might to figure out if cooling was good. Couple mile drive and it stayed at 185-190 the entire time. So I believe so. I think it's the stock distributor, but it doesn't appear to have a vacuum advance port. Can't find it on the car at all. No random vac lines, nothing. So confused.....
Old August 21st, 2012 | 01:23 PM
Supreme78's Avatar
And the engines not stock. Someone put diesel in it, so it's now bored .30 over, with a mild cam.
Old August 21st, 2012 | 01:51 PM
cutlassefi's Avatar
If it had diesel in it I'm surprised it even ran.
And it's .030 over not .30.
Old August 21st, 2012 | 04:56 PM
Is it an HEI distributor, still have the 69 points type, Pertronics?
jpc647
June 8th, 2013 07:39 PM
scooter123
April 13th, 2012 09:33 AM
fasteddi
July 15th, 2011 07:36 PM
projectheaven
June 21st, 2008 11:21 AM
musicars
September 1st, 2007 06:46 AM
