69 350 rebuild vs. 403 questions
Ok. Have a few questions about worthiness, value and some other things. To start with, have a 70 Cutlass Supreme ragtop with a 77 403 in it. Originally had 350 with 310 HP. Not sure about why it disappeared. Several owners through the years. 403 is running fine, just a bit doggy. Have opportunity to purchase a 2 barrel 350 with #5 heads. Pulled running, sitting for "2years". Would it add/change value to have a 350 back in the car? Would at least go with new 4 barrel intake. Everything else has been redone, (wheels, seats, carpet, paint, glass, etc.) Also read a previous thread about an Olds engine builder in NKC, Mo. Anybody with info or direction to the thread would be appreciated. I appreciate the input, you guys are full of great information. Thanks in advance, Kip.
Put #5 heads on your 403 with a mild cam. You will not know it is the same engine, from 7.8 to 1 to around 9 to 1. Then you can build the 350 if you want. The value won't be there unless numbers matching. Even then being a non performance version, it would matter less. Great car, would own one if I could afford it.
310 advertised HP, which was not really 310 HP. I had a bone stock 70 Supreme 350-4bbl (310 hp) and it ran the same as a friend's bone stock 72 Supreme 350-4bbl (200 hp).
So I wouldn't sweat the loss of the original engine and do as other said and put better heads on the 403.
88hurstolds
January 20th, 2020 11:39 AM
tomngary
May 19th, 2014 09:21 AM
1979403ta
June 30th, 2011 06:17 AM
