68 Cutlass 350 Rocket idling rough lately
Old Feb 10, 2012 | 07:34 PM
yeahbuddy's Avatar
I have a 68 Cutlass Supreme with 350 Rocket. It has an Edelbrock intake and 650 carb. It was running well until about a couple weeks ago. It has started to idle rough and also miss at idle. Yesterday the car died after I started it but fired right up after that. Not sure what is going on here. Any suggestions? I looked all the vacuum lines and they are all connected? It runs smooth when I am accelerating...except it starts to surge once I get to 40-50mph accelerating heavily. Then I need to let go of gas and accelerate soft and it drives fine. Get 40psi oil pressure at idle and 60 when driving.
Old Feb 10, 2012 | 09:08 PM
Lady72nRob71's Avatar
Did you flex the vac hoses around the connections looking for cracks there? Vacuum caps often break at the top. Carb still secure to the manifold? Plug wire come loose? Crappy gas?
Old Feb 11, 2012 | 05:49 AM
Beob's Avatar
I would also replace the fuel filter, could be clogged. For like 3 bucks its worth it anyway.
Old Feb 11, 2012 | 07:08 AM
When was the last time it was tuned? Points or Electronic ignition? Miles on engine?
ah64pilot
Dec 28, 2016 11:51 PM
droptopron
Dec 1, 2011 03:05 AM
MI455
Aug 30, 2010 12:24 PM
72Cutlass
Mar 23, 2008 02:41 PM
novice57
Oct 30, 2007 05:23 AM
