68 350 Brake Booster fitting and hose
Forgive me for being a n00b on this site, but I am putting together my first car that isn't a VW.
I'm currently rebuilding the brake system for my 68 cutlass original 350 engine and I cannot find the fitting line for the brake booster that connects to the intake manifold.
Though, I have found a repop on a few sites that states it will only fit for 69-72.
Can anyone confirm that this will will be okay to use:
http://www.fusickautomotiveproducts....p?number=IB692
http://www.opgi.com/cutlass/C240531/
Thank you for any help
As long as the threaded portion of the fitting is the same size as the port in your intake, it will work. If it's the wrong size, you can get a brass adapter fitting from the local hardware store.
If all you need is that 90º fitting for the intake, you could get a used one from a member here or maybe find one the right size at the hardware store.
zodiacblueS
Brakes/Hydraulic Systems
44
October 12th, 2014 03:22 PM
W-27
December 10th, 2013 10:25 AM
Del70
October 14th, 2010 04:55 PM
