67 Cutlass 330 ci 250 or 260HP?
Old Apr 11, 2025 | 03:17 AM
Lancealars's Avatar
Newby here. Just tinkering my new retirement toy. 1967 Cutlass convertible factory 4 speed, 12 bolt rear. 330 2bbl .
I'm just checking and documenting all the engine numbers I can NOT figure out if this 330 is a 250 or 260 hp.
I have a picture here of the small stamp on the drivers side head. And the cast number on top water pump is 394417/3.
Also, Im trying figure out if a bit over 4000 of this package of this Cutlass is rare or that's just a BS line the seller said.
Excellent forum site it's already saved me time and money! Lol
Old Apr 11, 2025 | 05:14 PM
69CSHC's Avatar
The 260 hp high compression 2 bbl did not come in Cutlass, it was a Delmont engine.
And the L on right side of head stamp in your pic confirms Low compression.
Old Apr 11, 2025 | 05:52 PM
69CSHC's Avatar
"1964 ~1967 code is stamped on the right head this code consists of a letter 330 v8=T than a production sequence number followed by a suffix code letter ( L=low compression E=2-bbl export G=high compression H=4-bbl quoted fro 442.com" Post #5 here https://classicoldsmobile.com/forums...ication-48352/
People love to say 442.com or OldsFaq is chock full of misinformation. The thing is it's also chock full of accurate information. Depending on the importance of the information being provided a proof check doesn't hurt. Especially if you are not familiar enough with Oldsmobile to notice subtle errors.
Page 15 of the specs booklet here https://xr793.com/wp-content/uploads...CS-Booklet.pdf
And Automobile Catalog. Here are engine options for 1967 Cutlass Convertible.
155hp 250 cid
250hp 330 cid
320hp 330 cid
Old Apr 11, 2025 | 05:57 PM
69CSHC's Avatar
Code W on head stamp.
"1964-67 V8 models engine code is stamped on the right cylinder head. This code conlsists of a prefix letter (330 V8=T(1964-65) or W(1966-67), 400 V8 = V), then a production sequence number, followed by a suffix eode letter (L = Low compresdon, E = 2-bbl export, G = High compression, H = 4-bbl export). A 2-letter code on the oil filler tube identified the engine."
Page 1 here. https://www.thepartsplaceinc.com/dat...%20Decoder.pdf
67CutlassNut
Jan 31, 2020 12:01 PM
MudEye
Jun 2, 2015 10:45 AM
morgan99
Jan 22, 2015 04:59 PM
67cutlass67GS
Apr 17, 2014 03:14 PM
pbarney
Dec 17, 2013 09:55 AM
