59 371 fuel pump milesmaster
The 371 has a 5-9 psi electric fuel pump inline to the std mechanical fuel pump. Basically a transfer pump from gas tank to fuel pump. There is also a milesmaster fuel pressure regulator at the 2 barrel carb. Will the carb handle 5-9 psi if i eliminate the mechanical pump? Also where can i find a cover plate for the fuel pump mount? And what the heck is a milesmaster ?
thanks for any and all advice
Gone Johnson
May 18th, 2020 07:22 PM
