#5 Head build
Old Jun 8, 2014 | 06:29 PM
cycomiko's Avatar
#5 Head build
sorry I'm still new to building my own engine etc. Im trying to buy the parts to get my heads built slowly since money is an issue. I know the bigger valves are available for these heads but should I go with the stock size 1.875 and 1.562? Its going to be in a mild build that I will drive on the road around 400hp ish. I've heard that there are some issues that need to be considered in order to use the bigger valves. I've found the stock size Sealed Power valves all 16 for around 100 bucks. What else should I get for these heads besides the springs and rockers? Sorry for the newbie questions
Old Jun 8, 2014 | 06:30 PM
coppercutlass's Avatar
Chevy budget Olds powered
check out the home porting thread on the racing and performance section. it covers many very good pros and cons.
Old Jun 9, 2014 | 07:08 AM
cutlassefi's Avatar
If you're truly looking for 400hp then you'll need to do at least a real good cleanup on the bowls and ports. On top of that filling the crossovers and welding up the center dividers is a must as well.
But that's only after you make sure the guides, seats and surfaces don't require any additional work.
I know this is a do as you save project, but you may want to take a pencil to it first. You have the option of going with aluminum heads, which would require additional pieces and milling, to make your goal much easier to reach.
Jmo
Old Jun 9, 2014 | 04:16 PM
jag1886's Avatar
If you truly want 400HP from a 350 Olds that is not a mild build. I happen to have a completely built set of #5 heads that I used for one summer, I spent $1100 on them, I'd sell them for $400 plus shipping.
Old Jun 9, 2014 | 06:47 PM
cycomiko's Avatar
That is tempting. What has been done to them and what size valves, springs, etc..Any Pictures? I wonder how much shipping would be to 08081
Old Jun 10, 2014 | 04:37 AM
Smitty275's Avatar
Engine Builder
Those heads will easily accept 2.072/1.625 valve combination and it'll really wake up from the size increase. I'd start with Milodon valvesxand gave their 1.710 exhaust valve turned down to the 1.625 head diameter.
Old Jun 11, 2014 | 08:15 PM
cycomiko's Avatar
Has anyone ever used the Lunati roller rocker arms 85410lun ? Ive found them on sale for a great price. They would be for the num 5 head build.
Old Jun 11, 2014 | 08:20 PM
cutlassefi's Avatar
Only if you're going to use a 7/16 rocker stud, are you?
Old Jun 11, 2014 | 08:28 PM
cycomiko's Avatar
I dont know. Should I not? Sorrry I'm a newbie
Old Jun 12, 2014 | 02:30 AM
Smitty275's Avatar
Engine Builder
Going with a 7/16 stud mount rocjer is an excellent idea. But now your talking more money into your heads to drill & tap the 16 rocker mount holes which puts you all the closer to costing the same as you would have in a set of ProComps which would save you a ton of hassle and provide better results.
Old Jun 12, 2014 | 02:33 AM
Smitty275's Avatar
Engine Builder
What's considered a "great price" on those rockers?
Old Jun 12, 2014 | 09:11 AM
cycomiko's Avatar
$150
Old Jun 12, 2014 | 11:49 AM
cycomiko's Avatar
oh well I just ordered them like I said for the price I couldnt refuse. Lunati has a closeout sale on them for 150 plus shipping. If anyone is interested they are available at that price by phone only untill sold out
young olds
Jun 3, 2014 08:13 PM
Olds Scott
May 29, 2013 08:15 PM
Chris Wicks
Oct 21, 2012 09:35 AM
Ragtopw1972
Oct 18, 2012 08:19 AM
CLcutlass
Aug 21, 2011 06:25 PM
