455 heads on 403
Old Jun 7, 2011 | 06:57 PM
oldsy's Avatar
olds403guy
Thumbs up 455 heads on 403
i was just wondering how well will some G heads off of a 71' 455 work on a 403?can i boost the compression with these heads???
Old Jun 7, 2011 | 09:01 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
You'd be way better off using small block heads. You won't gain compression with the BBO heads.
Old Jun 8, 2011 | 06:58 AM
Why is everyone so fixated on compression instead of port flow? I've always said that if the BBO heads worked on a 400 big block, they should work equally well on a 403 small block. Yeah, there's no increase in CR, but there's no decrease, either. If you're building the 403 from scratch, select pistons to get the desired CR with the 80 cc chambers on the BBO heads. And you probably already know that only a few SBO intakes have sufficient meat to port them to match the BBO heads.
Old Jun 8, 2011 | 07:33 AM
TripDeuces's Avatar
Joe you're not allowed to use logic. This is the instant gratification era where everything must be handed to you in triplicate. You're almost sounding old and farty like me.
Old Jun 8, 2011 | 08:56 AM
Actually, that was the cabbage from last night's dinner...
Old Jun 8, 2011 | 09:14 AM
You made me chuckle fellas.
Just answering his question.
403+Gheads does not equal more compression.
I think the whole small block head vs big block head on a 403 debate boils down to money and effort.
It's a lot easier for people to swap heads, than it is to swap pistons.
If the engine is removed, then all the mightaswells would start to play differently.
Old Jun 8, 2011 | 09:30 AM
TripDeuces's Avatar
Hmmm, cabbage.............
Old Jun 8, 2011 | 10:27 AM
oldsy's Avatar
olds403guy
thanks.thats what im trying to do...im making an effort to save money because im on a short budget and "playing" with what i already have
88hurstolds
Jan 20, 2020 11:39 AM
QS442
Jun 12, 2014 06:47 PM
J-(Chicago)
Feb 26, 2014 09:14 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
DarkStar
Oct 21, 2009 07:35 AM
