403 timing question
403 timing question
Bone stock’77 Vista Cruiser, EGR/ smog deleted (broken) and distributor vacuum line tee’d from transmission (manifold).
With distributor line disconnected and plugged it’s at 10* advance.
The timing chain came loose on a lemons rally, we installed a new set and I think the timing is off. We initially installed the timing 180 out so I reinstalled the distributor with the rotor pointing at #1 at TDC (0 mark on timing tab).
10* is all I can get without the vacuum hitting the firewall. Car runs smooth at idle, bogs at part throttle.
Main question: what should my timing be at with the distributor vacuum plugged?
Thanks in advance (no pun intended).
I was thinking I need to advance it a tooth. What ballpark degree should I be aiming for with the emissions stuff bypassed? Stock system was a weird hybrid ported w/EGR and a spark advance modulator that was found broken in the glovebox. I can’t tell if 10* is too much or not enough, great in P or N but a bog dog in D. It was not this boggy before the timing chain came loose, but when that happened any “how was it before” info went out the window.
You want the 20 degree at 1100 rpm, that is usually the spec. I have seen 13 to 22 degrees at 1100 on Olds V8'S, so it does vary some. You can put the spark plug wires one post back to get enough advance without removing the distributor.
Thanks!
If an engine is at TDC on the compression stroke, then rotated in the shortest direction to the base timing spec e.g.' 20° before stabbing the distributor with the rotor pointing at #1 it will start much more easily. When the engine is left at TDC 0° on the compression stroke and the spec is 20° the engine is struggling to start due to the timing being off by 20°.
She's back!
@oldcutlass @olds 307 and 403 @joe_padavano @Sugar Bear
Thanks for the help fellas. I reinstalled distributor around 16*, did some ear tweaking and she's back! No bog at part or full throttle -- there may be further tweaking required but I'm gonna go cruise some Vistas and enjoy that marshmellow ride!
In case anyone else runs into timing problems after losing a chain: The fuel pump fits in perfectly at #1 TDC, but will not seat at #6 TDC. Lesson learned.
Thanks again for all of your help, I'll put up some pics of the old girl in the general thread soon. A basket case but FUN!
dingusboy
April 2nd, 2009 02:56 AM
