403 Stock Intake v.s. Edelbrock 3711/2711 Performer
I am currently rebuilding a 403 and I'm wondering what are the performance advantages of using the Edelbrock Performer over the stock intake. I've heard that the Performer is basically a lighter copy of the Olds intake, if that's the case then the only thing I'm sacrificing is a few extra pounds.
I also plan on removing the EGR valve, would it be better to buy the Edelbrock 2711 (which offers no EGR spot) or is it just as effective to block it off on the existing manifold.
Any answers would be super duper awesome
The Edelbrock will add about 5 to 10 HP better air flow into the engine. Also you have more choices of carbs. that you can use. If you don't plan on using a EGR than get the 2711.
For most people it is a mater of money, because they just look cool when open the hood, and any extra HP is always a plus.
The A4 intake will fit on the 403. you need to make sure that you get the A4 and not the A5 though, the A4 has bigger runners from what I understand. I am rebuilding the 403 in my T/A and am going to be using the A4 intake on my engine. I am doing it because I want the better flow over the stock one and the stock look. I am trying to build a sleeper so I wanted an intake that doesn't say Edelbrock or anything on it, but still has great performance.
Tony72Cutlass'S'
July 12th, 2011 06:29 AM
