371 Oil Pressure issue
Old Nov 20, 2018 | 10:30 AM
CholmondeleyWarner's Avatar
I recently changed the canister filter housing on my 1957 371 since the old one had a damaged thread, and now the car is slow to build oil pressure and knocks badly for a about 2-5 seconds when cold starting until oil pressure builds. Maybe the housing I put on was defective? The housings have a small spring loaded valve in them, but I was under the impression these years didn't have any provision for an anti-drainback valve. Any input would be appreciated.
Old Nov 21, 2018 | 04:35 AM
Ozzie's Avatar
Did you only change this
or the bracket also? Just changing the "can" (shown) shouldn't affect the oil pump performance, assuming the one you installed was correct. The valve you refer to likely is a bypass to accommodate a congested filter. Retrace your steps to find the shortfall. I'm assuming that the oil was not removed from the engine to perform your job.
Old Nov 21, 2018 | 08:31 AM
Tedd Thompson's Avatar
You pretty much have to remove the oil if you replace the canister or the housing. Did you change to a spin off type housing or just replaced the old system?.... Tedd
Old Nov 22, 2018 | 11:21 AM
Originally Posted by Ozzie
Did you only change this or the bracket also?
I replaced the entire housing/bracket, still using the OEM canister style filter.
SBORule
Feb 19, 2022 02:40 PM
Gascoop
Jul 25, 2018 11:26 AM
Stevec
Sep 6, 2016 02:44 PM
J-(Chicago)
May 28, 2014 03:03 AM
1001coins
Apr 23, 2014 06:11 PM
