371 oil leak
Old Apr 21, 2020 | 09:05 PM
Brownie12's Avatar
371 oil leak
Gidday
our new addition also has an engine oil leak at the front ...is only a tad overfull ...are these engines really fussy about levels 🤔🤔🤔...once again it is not sprayed everywhere so dont think it is front seal......engine has been rebuilt , not by us though. Is there a bolt or something that opens right through to the crankcase that can leak 🤔🤔🤔
thanks Brownie
Old Apr 24, 2020 | 12:38 PM
D. Yaros's Avatar
Try tightening the oil pan bolts, in the event the source of the leak is the pan gasket.
Old Apr 25, 2020 | 03:10 PM
They aren't fussy being a bit overfilled. Isolate the point where its leaking to come up with a plan of attack.
Old Apr 25, 2020 | 07:12 PM
Tedd Thompson's Avatar
What other Eric said. If mine I would get after it with a grease remover and a pressure washer. Sometimes a leak will travel quite a ways before it makes itself noticed...... Tedd
Old Apr 26, 2020 | 02:22 PM
Brownie12's Avatar
Thanks ..
will check all of the above ....thanks for help
Brownie
Brownie12
Apr 15, 2020 06:37 PM
brandon 455
Jul 10, 2013 06:09 PM
jasmit29
Sep 14, 2012 08:34 AM
justinj
Mar 21, 2012 04:52 PM
rl55s88
Oct 10, 2011 07:30 PM
