350 Rocket Help
Old Aug 1, 2013 | 05:05 AM
TexasGunner's Avatar
350 Rocket Help
I am in need of a engine for my 72 olds. I found a 350 rocket for sale. The seller has listed it has a 1970 engine and is asking $400. Do ya think its worth it? How can I tell what year the engine is? Thanks in advance.
Old Aug 1, 2013 | 05:24 AM
Oldsguy's Avatar
Past Administrator
Use this information from our site. It will help you out. I don't believe it is '70 vintage though.
Old Aug 1, 2013 | 05:28 AM
Thanks Oldsguy. How can you tell its not vintage?
Old Aug 1, 2013 | 05:42 AM
1970cs's Avatar
Lansing built
I agree with oldsguy, HEI distributor (could have been added) and EGR
Pat
Old Aug 1, 2013 | 06:32 AM
brown7373's Avatar
Does it run, or is it going to be a total rebuild?
Old Aug 1, 2013 | 06:35 AM
RetroRanger's Avatar
72 Olds CS
Mid 70s valve covers nd new alt style as well
Old Aug 1, 2013 | 10:03 AM
jpc647's Avatar
73-74 only I think.
Old Aug 1, 2013 | 10:43 AM
This appears to be a frankenmotor, as there are parts from various years. 1973-74 valve covers, 1973-up intake, HEI, late 1970s alternator bracket, aftermarket carb. Check the VIN derivative and block and head casting numbers. From the photos there's no way to tell what year this is.
Old Aug 1, 2013 | 10:54 AM
tru-blue 442's Avatar
Old School Olds
I'd make a wager that if you
posted the head numbers, timing
pad numbers, and the vin pad #'s it make come up
a 68-72, as far as the block and heads anyway.
Old Aug 1, 2013 | 11:33 AM
1970-W30's Avatar
Also the drivers side exhaust manifold is not from a 1970 A body .......
rcrac3r's Avatar
Curious that the cross over port on the right side manifold is pointed up instead of down.
Old Aug 1, 2013 | 12:12 PM
1970-W30's Avatar
Didn't notice the weird crossover port.....What body style would use that type of exhaust configuration?
Old Aug 1, 2013 | 12:29 PM
That's not a "crossover port", that's the outlet. It's a Toro manifold.
Old Aug 1, 2013 | 02:14 PM
I love this forum. Thanks for all the info guys. The seller said it was ready to run. I have not seen the engine in person. I was thinking about making the trip to go see it Sunday. But also given all the info on here I am also thinking about passing on this one.
Old Aug 1, 2013 | 05:10 PM
DoubleV's Avatar
Ask the guy what heads are on it. If it's really a 70, then they should be the 6 heads. My guess is they are the later 8 heads.
Old Aug 1, 2013 | 05:37 PM
Octania's Avatar
ditto what VV said
OTOH make a call and have the # on the corner of the head related to you.
If it has #6 heads, it's worth a bit more attention.
If it's a runner #8 headed 1973 engine, which the top end looks like, still not a bad base to start with.
Depends on your budget and needs.
69OLDSCUTCONV
Feb 1, 2011 06:09 AM
cutlassKing
Nov 29, 2010 03:05 PM
gscott819
Jul 28, 2009 07:02 PM
esisson
May 22, 2008 07:47 PM
<Eddie>
Nov 1, 2005 07:30 PM
