350 rocket help
350 rocket help
i have a 72 olds 350 ive started buying up parts that im going to put on in the winter. as im going through various catologs i notice that parts arnt listed for old, so the parts from the chevy 350 small block are the same? how can i find out what body stlye...a boby...f body...x body? 4 bolt main? summits catalog lists different cars and years but allways chevy ford and there models.
thanks
thanks
There aren't as many Oldsmobiles and there aren't as many aftermarket parts although there are enough to do most things needed. Parts will cost a little more because of the demand and supply law of economics. The catalogues are basically advertisements and they put their money where it will bring the most return. It doesn't mean that whatever you are looking for isn't available for your engine. Sometimes a call will get you a satisfactory answer. The Chevy engine isn't the same as the Oldsmobile engine or the Ford for that matter, the 350s are diffferent as day and night and parts won't interchange (except maybe the generic 14 inch air cleaner element or something like that). A 1972 Olds Cutlass is an A body car. A Delta or a 98 is a B body car. The Omega is an F body.... I think, I don't know what the toronado is. Oldsmobile engines did not use 4 bolt mains from the factory, didn't need them.
thanks ill have to call i just dont know if i trust the operators anyway ive been looking to replace entire brake system and headders. i think the exhaust manifolds are different sizes from each other passenger is longer then drivers side.
Note that if you're looking through catalogs like Summit and Jegs, their paper catalogs don't list everything they stock. Since space is limited, they only show the more popular items in the catalogs. Check their on-line catalogs for a greater selection.
I've been getting parts from Summit for years and they will be the first to tell you that if they listed all the parts they carry (which is everything you need for an Olds) the catalog would be the size of the New York phone book.
A good set of headers for your Cutlass might be tricky to find, but not brakes. If you're lookin' at a set of brakes that will fit the 68-72 Chevelle, Malibu, GTO, Lemans, Tempest, Skylark, Beaumont or even the 70-72 Monte Carlo, they'll fit your Cutlass. I think all those A-body suspension components are swapable too.
- GoldOlds
- GoldOlds
cutlassKing
November 29th, 2010 03:05 PM
gscott819
July 28th, 2009 07:02 PM
esisson
May 22nd, 2008 07:47 PM
