350 Performance Cam
350 Performance Cam
Let's try this again...I'm sure this question has been asked time and again, but I couldn't find any answers on the search tool...what is the best performance cam to use on a stock 350 without having to replace lifters, pushrods and rockers? 350 has dual crossover exhaust and quadrajet.
Always.............ALWAYS use new lifters with a new cam, or even a used one for that matter if you don't have the originals marked as to which lobe they came off of. Otherwise you WILL wipe out the cam.
Also you should check the length of the pushrods needed with a pushrod length checking tool to be on the safe side to make sure you have the correct length pushrods.
As far as the stock rockers go they say not to go over .500 lift at the valve with them. I ran a .504/.504 cam for 5 years with no issues.
Also when you replace the cam you should get new valve springs and all the hardware that goes with them.
John
Virtually any cam with less than .500 lift and intake duration of no more than 215 or so can be used. I don't endorse Edelbrock Performer cams, too lazy. There are better ones out there imo.
By the same token, don't get anything too aggressive, that will require a better spring.
Lunati, and some of the smaller Comp stuff is fine. Erson makes a few that are very streetable as well.
Good luck.
Good luck.
Thanks for the great feedback...I read in a SBC rebuild manual that you could reuse the pushrods...and suggested flipping them over. I've "baggied" all my parts based on cylinder number, and wasn't planning on reusing the lifters (slightly concave)...I see a little wear in the cam along the outside edges of some lobes. I also notice a very slight ridge at the top of the cylinders, which will need to be reamed, before I pull the pistons.
I'm a Lunati fan too but you have to watch how aggressive you get with the stock valve train, especially those stock rock solid rocker bridges! Maybe a Lunati VooDoo isn't the best choice.
If you have stock heads with a stock valve train I'd go with some thing around .500 lift as mentioned but also something a bit less aggessive.
Erson, Lunati and others make cams more suited to this application. Check em out.
oh dont get me wrong.. i want the car to be fast, but i also like the lopey cam sound, i dont mean all out drag style lope, but mild street to where u can hear that it is cammed.
A nice duel exhaust will help with the sound plus the cam. You don't want to go to big with the cam unless you plan on doing more then just a cam swap.
Yes and no. Not everybody has a complete list of cams for Olds. They're more choices then Crane. I have a Dick Miller Racing catalog it has 5 pages or more of cams. Any cam company can custom grid a cam.
Best two cams I've used in an Olds 350 are the Lunati 318A2 and Comp Cams Extreme Energy cam XE262H(Duration @.050 218/224 Lift 475"/.480" LSA110). Lunati specs are very similar to the Comp Cam. Both provide a good idle and around 14-15 inches of vacuum.
with lunati cam 318a2 can I use my rebuilt stock #6 heads and stock torque converter I have 120,000 on original motor
You should start a thread of your own with questions, that way you won't be pulling up old threads here.
You will get much more help starting a 350 build thread under small blocks.
Good luck with your build
Eric
there are a "bunch" of GM 350's. buick has one, pontiac has one, chevy has one and olds has one. there are NO "interchangable parts" on Any of them. they are all "TOTALLY DIFFERENT". You could use the carb, but it also is Different from one make to another.
wmachine
December 30th, 2009 05:55 AM
