350 olds build
Old Sep 1, 2022 | 10:09 AM
deadeyejedi's Avatar
350 olds build
Can I get some honest opinons on these specs. It’s a potential buy but there’s too much math for me figure out compression ratio and a little guess work . To my knowledge the block hasn’t been milled down . I’m going to look at the car it’s in tonight . Thank you
Old Sep 1, 2022 | 03:45 PM
checked the car out tonight looked and ran nice had a touch of valve train noise and a skip at idle nothing to write home about . After doing some ciphering on my own this engine must be around 10.5 :1 compression if we assume the .060 off the g a heads brings it to roughly a 65cc head (correct me if im wrong)still on the fence about buying it.
Old Sep 1, 2022 | 05:09 PM
bccan's Avatar
Piston dish can be looked up from part #, the only thing I see missing is deck clearance, without it you’re still guessing at CR.
Old Sep 1, 2022 | 05:10 PM
Sugar Bear's Avatar
Any chance of doing a compression test before purchase?
Old Sep 1, 2022 | 05:29 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
My guess it about 9.8 to 1. Take 10cc off of a 82cc chamber for 72cc, going by the .006" per CC. I say about .050" piston to deck with a .028" head gasket and the Speedpro flat top forged .020" or so below deck. It should run pretty decent with the right converter and gear.
Old Sep 1, 2022 | 06:43 PM
He did tell me it had a 3200 stall and 342 gears. And to his knowledge the block wasn’t decked most of what I’ve read so far with that flat top piston it sets about .025 in the hole.
Old Sep 1, 2022 | 06:50 PM
i may ask him
Old Sep 2, 2022 | 05:04 AM
Dynoking's Avatar
Originally Posted by deadeyejedi
checked the car out tonight looked and ran nice had a touch of valve train noise and a skip at idle nothing to write home about.
Valve train noise and a skip at idle is something to right home about. Because you do not know what the cause is it should be assumed costly internal engine repair. If you think or the seller claims he doesn't know the cause(s) you're fooling yourself. I would not get involved in some one else's headache with out a major price concession or better yet just walk away. CO friends don't let friends buy expensive headaches!
Old Sep 2, 2022 | 05:20 AM
you have a good point I certainly don’t need and expensive headache . This engine may have been well thought out in the beginning but is now starting to show it’s age . It would be nice if I could talk to the previous owner about the build . The car itself is pretty nice but not nice enough if it needs engine work . Thanks to all for the replies I’m going to sit on this one a while
Old Sep 2, 2022 | 02:22 PM
Toocool's Avatar
3200 stall is a lot, have you driven a car with that stall? I had a 3000 stall in a 600hp Chevelle and hated it. It will be great at launch but otherwise it wont be much fun. Having all the specs for the engine is pretty cool, most people that buy a car with a rebuilt engine have no idea what they are getting.
Old Sep 2, 2022 | 07:57 PM
Doesn't that depend upon the converter? I have read that a "tight" converter will drive like normal under light throttle, but will go the stall RPM with torque applied (wide open throttle). Seems the high stall budget converters have a lot of slip during regular driving, similar to what you posted, but the high end converters don't.
Old Sep 2, 2022 | 08:02 PM
66SportCoupe's Avatar
I agree. My tight 3800 stall is more than drivable on the street. It's not a cheap converter though.
Old Sep 3, 2022 | 08:17 AM
Toocool's Avatar
My FTI convertor was not cheap but I just didnt like it as a daily driver. I fixed it by installing a Tremec TKX.
Old Sep 3, 2022 | 08:47 AM
The guy said it has a tci turbo 350 trans but hard telling the brand convertor he has in it . He was driving it daily for whatever that’s worth.
Old Sep 4, 2022 | 08:12 PM
442Dude's Avatar
You will love the new TKX......I know I do in my resto mod.
Old Sep 5, 2022 | 07:59 AM
Well that sounds like a fun fix to your issue!
Old Mar 9, 2023 | 04:39 PM
man you were spot on ! Im glad i passed on the car the motor didn't last too long after this post .Lost a lifter and the cam .
Old Mar 10, 2023 | 06:10 AM
brownbomber77's Avatar
Who was the unlucky buyer..??
Old Mar 10, 2023 | 07:14 AM
not sure was on Facebook marketplace he has a motor for the car though. Sounds like he’s trying to recoup some of his money . Not ever sure what he paid for it in the beginning .
shoehorn_hands
Apr 5, 2020 05:06 PM
Kyron219
Dec 30, 2015 07:17 PM
73-s
Jun 11, 2015 03:10 PM
OMEGA
Sep 6, 2009 07:42 AM
78cutlass
Feb 11, 2008 06:52 PM
