350 keeps firing after ignition is turned off
Old June 8th, 2010 | 11:33 AM
Svinet's Avatar
F-85 Cutlass Coupe owner
Unhappy 350 keeps firing after ignition is turned off
Hey guys
When I swapped out my old and bad Accel ignition wires for my new MSD the engine kept firing one or two cylinders after I turned the ignition off.
I guess I can fix this by doing something to the Mallory distributor but what and how?
Help is very much appreciated.
Thanks!
Regards
Anders
Old June 8th, 2010 | 11:35 AM
70 cutlass s's Avatar
What is your timing set at?
Old June 8th, 2010 | 12:53 PM
cutlassefi's Avatar
Chances are it has nothing to do with the ignition.
It's called "run on", caused by deposits, high idle, overall improper tune or a combination thereof.
IMO you're wasting your time and money on replacing parts at this point.
Old June 8th, 2010 | 01:07 PM
1966_F85's Avatar
Carbon build up is probably the cause of the problem like cutlassefi said.
IMHO get your self some Sea Foam or a spray bottle of water and do an old fashion carbon build up removal.
Old June 8th, 2010 | 05:31 PM
Svinet's Avatar
70 cutlass s, I don't know. I'm a V8 newbie so go easy
cutlassfi, I put on a new carburator since the old one was in pretty bad shape. So getting this calibrated might stop my problem? Idle is about 900 RPMs. Thats pretty high right?
I do not wish to buy any parts at this point
1966_F85, Carbon removal? Newbie, sorry
Thanks for you replies guys! Very much appreciated!
Cheers
Old June 8th, 2010 | 07:41 PM
Mingus's Avatar
It can also be from bad/low octane gas or timing. Did you change plugs when you changed wires? If they have deposits on them they can create hot spots and ignite the fuel.
Old June 8th, 2010 | 07:48 PM
cutlassefi's Avatar
If it's a stock setup set the idle at 750 or so after correct mixture adjustment. Make sure you have the right heat range plugs in it. Then either pour trans fluid or water SLOWLY down the carb throat while running being careful not to get any in the bowl vents. Rev it every once in awhile. Also make sure the engine temp isn't excessively high as well. Start with that and let us know.
Old June 8th, 2010 | 07:50 PM
jaunty75's Avatar
It's not going to get at the cause of your problem, but one way to stop the dieseling is to turn the ignition off with the car still in Drive (or Reverse, or some gear), rather than Park, so there is a load on the engine. Then put the car in Park and take out the key.
Old June 13th, 2010 | 04:43 PM
drec02's Avatar
I just started my engine for the first time and was begining to break in my cam when I needed to shut the engine off(oil leak) and I experienced this same problem. I hope I didn't damage my valvetrain because it fell below 1500 rpm for about 2 mins as I was attempting to shut it down(ended up disconnecting power wire from tach). What do you guys think is the problem as everything on my motor is brand new. Plugs, wires, HEI distributor, Carburetor, etc. I did not get to adjust my idle, mixture screws or fiddle with the timing as I was concerned I may have done some damage to the new valvetrain. Plugs are gapped at .40 should I open them up, or maybe back off the timing, or lean out the carb??? Dish out the suggestions experts.....
Old June 13th, 2010 | 07:05 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Make sure your throttle return spring is closing the air dams all the way.
Old June 13th, 2010 | 07:51 PM
Blk71SX's Avatar
what does timing have to do with it if the key is off and no fire is coming from the coil?
Old June 13th, 2010 | 08:16 PM
It wouldn't have to do with the coil. It goes back to what Mark was talking about with improper tuning. If the timing wasn't right then the air/fuel mixture more then likely be set wrong as well. Just overall improper tuning. Which the effects have been talked about in this tread. Since reading the replies I didn't see a point to repeat the same info. So I didn't post. Sorry I didn't go into more detail before.
Old June 13th, 2010 | 08:34 PM
Blk71SX's Avatar
I've seen post after post in many different forums when someone in having a problem with dieseling to check the timing. Since the plugs aren't firing it makes no difference what the timing is. The engines of the early 70s era were plagued with the problem. Yes, lean idle mixtures contribute to the problem (those carbs had devices installed to deny access to the mixture screws for emission regulations) as well as carbon build up in the cylinders either raising the cr or leaving hot spots to act as glow plugs as in diesel engines. raising the octane of the fuel and/or lowering the idle speed as little as 25 rpm can make a difference. Some engines were so bad nothing helped except keeping them in gear, using the trans or clutch to kill the engine
Old June 14th, 2010 | 06:35 AM
Svinet's Avatar
I believe setting the idle and the air/fuel mixture right should fix this. Shutting the car off in gear solves the problem until then.
I will report back when I, hopefully, have solved my problem.
Thanks guys!
Old June 15th, 2010 | 12:09 PM
Svinet's Avatar
Fixed the problem. Set idle lower and adjust air/fuel. Works wonders
SouthCarolinaCutlass
December 31st, 2014 08:33 AM
Kirk455
July 2nd, 2013 09:10 AM
liquidpower
December 30th, 2010 10:20 AM
66ninetyeightls
Ninety-Eight
August 2nd, 2010 02:33 PM
88 custom
April 16th, 2010 12:45 PM
Quick Reply: 350 keeps firing after ignition is turned off
