350, jumping ahead of myself a bit tho...
#41
oh DANG! did i accidently start a fued online asking for the dirty details on building a fun 350?
NO OFFENSE to anyone, and no hard feelings to anyone using my topic as a battle ground.
So i purchased the 330 crank, taking it in to the machine shop once i purchase the 6.200" rods so they can grind down the journals to the chevy rods and widen them for the increased width of the rods, CORRECT??
ill be buying std sbc 400 forged pistons, so when it comes time for the motor to go together the block can be bored and ran with those and the rest of the bottom end.
...then convert over to a 330-425 flexplate. i think i got the jist of the bottom end stroker build, if wrong please adjust the little bit i have wrong. I tried to skip over alot of the arguments for i dont want to get tied up in that, again no offense.
If you stroke the crank to 3.5" inches by offset grinding the rod journals on the crank down to the small journal SBC 2.00" size and buy 6.00" long SBC Rods instead of 6.200", you can pick up a set of CP pistons that are made for an Oldsmobile with the right valve reliefs and Compression height for use with a 3.5" stroke crank and 6" inch rods, unlike the SBC pistons that have 23 degree valve reliefs instead of the 8 degree valve reliefs an Oldsmobile uses. Not that their won't be enough valve to piston clearance if a SBC is used and lift is less than .560" the CP pistons would set you back a few hundred more bucks. Stock stroke crank, cut rod journals down .025" for a 2.100" large journal SBC rod. The width you widden the crank journals depends on what kind of clearances you are going to run, if you are going to run loose clearances, then you wouldn't want to widden the rod journals as much if you are going with say .025 to .027" clearances as opposed to .030-.035" clearances. Side clearances are set to allow/restrict oil flow through the bearings, depending on desired rod bearing clearances you plan to run and thus, how much to widden the rod journals on the crank.
If you really want to know what to do and what to have your machinist do, you should contact Bill Travoto at BTR via email at bill@btrperformance.com or call him at 585-303-7560 or go to his website at http://www.btrperformance.com and or http://www.highperformanceolds.com
He has everything you need in stock.
He also has a 10 part video series on YouTube that anyone building an Oldsmobile engine should watch, just go to YouTube and type in BTR S71 Turbo and that should get you in the neighborhood.
#42
The perfect 350 to start with is Diesel, preferably the D block version not the DX block because the D block has .842" lifter bores and that saves money not having to bush the lifter bores down from .921" like you do in the DX block, unless you want to use stock type Hyd Roller lifters, not the best but doable.
If you stroke the crank to 3.5" inches by offset grinding the rod journals on the crank down to the small journal SBC 2.00" size, you can pick up a set of CP pistons that are made for an Oldsmobile, unlike the SBC pistons that have 23 degree valve reliefs instead of the 8 degree valve reliefs an Oldsmobile uses. Not that their won't be enough valve to piston clearance if a SBC is used and lift is less than .560" the CP pistons would set you back a few hundred more bucks. Stock stroke crank, cut rod journals down .025" for a 2.100" large journal SBC rod. The width you widden the crank journals depends on what kind of clearances you are going to run, if you are going to run loose clearances, then you wouldn't want to widden the rod journals as much if you are going with say .025 to .027" clearances as opposed to .030-.035" clearances. Side clearances are set to allow/restrict oil flow through the bearings, depending on desired rod bearing clearances you plan to run and thus, how much to widden the rod journals on the crank.
Which CP pistons are you referring to on the stroker? Custom? Also, most shops will cut reliefs for a hundred bucks, just get flat tops and cut reliefs or dish as required.
#43
Some early, first run D Blocks had main bolt issues, just need to drill and tap those threads a little deeper, no big deal.
The CP pistons are available from BTR off the shelf and are in stock for a SBO with a 3.5" stroke crank for use with SBC 6.00" rods.
Well, I guess you could get these pistons, rods, rings etc. from other places if you want to gamble and roll the dice.
#44
#45
O.K for the record SBORules post is a little confusing.
The D block takes a 3.00" main/425 or similar crank so you're not going to be able to cut it down anywhere near the SBC rod journal size with a 3.5" stroke.
Secondly Olds engines are not 'interference" engines, you can use a 23 degree Chevy piston with no issues, unless maybe you've got .650 lift on a tight lobe sep.
And for the last time don't widen the rod journal anymore than you have to, cut the rods instead, it'll reduce some of the offset.
SBORule, please don't post your "how to hot rod/stroke a SBO", I don't have enough time to edit it.![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
71boosted-good luck in your build. Let me know if I can help in any way.
#46
Jim, Summit carries those pistons. They also make 350 pistons in a 4.065" bore with stock olds rods and stroke, then a hone is all that is needed. I just wish all the avialable, quality pistons weren't flat top. I know most performance builds want that compression, tough to keep under mid 9's.
#48
Learn something new everyday, here is the link to the strokers,
http://www.summitracing.com/parts/cn...ake/oldsmobile
This is a perfect application for the #8 head. Flat tops and the #8 head put Cr in the low 9.xx range. Or, use the Pro Comps.
#49
That what I was thinking for the 4x4 350 build, mildly done #8's would yield perfect compression for the TBI fuel injection. The 5A 307 heads on there now, would yield 10+ to 1.
#52
Not sure how. Speed Pros are $400+ and you can't get Olds rods for $200. Also, I am going to take an educated guess and assume the CP pistons are quite superior to the Speed Pros. And as 307/403 stated, with 68-72 350 heads cr is too high, though it is a simple matter to cut a dish into them.
#56
#57
Who's 6.200" SBC rod are you going to use ? A good set of I-Beam rods are good in engines in the 500 to 600HP range and weigh less than H-beam rods.
#58
#59
You could use the stock crank that came in the diesel block and have the rod journals turned down to 2.100" no problem, even 2.000" is more than likely safe. You wouldn't need main spacers in the block and gas block caps like you would if you wanted to use a 330 crank. The stock Diesel cranks can handle 600HP like the 350 N cranks can. 330 cranks are good for up to 800HP.
Believe me, you go more than .580" and the valves will be kissing the pistons.
I'll agree you shouldn't widen the rod journal anymore than needed to achive proper side clearances on the SBC rods based on rod bearing clearances that will be engineered into the crank.
You do seem to enjoy giving bad advice.
In other words, let him know if he can sell you something.
If you're only going to 4.125 bore or so with a 3.5" stroke, why do you need to use a diesel block? Your hp is limited by the stock cast crank iron diesel crank anyway. Didn't think of that did you. And at that rpm/hp level why would you want to use a crank with a 3.00" main vs one with a 2.50? You can easily use the gas block for that hp level. That doesnt make sense to me.
Seeing as how all Olds share the same style heads, explain this to us.
I did an iron headed 455 with .584/.592 lift hyd roller, why did the valve not hit the pistons? I had over .150 valve to piston clearence, at overlap. Got any answers for that? Give an example of a build you've done that had over .580 lift where the pistons threatened the valves. I'm all ears.
The simple truth is you're wrong. Olds valve angle doesn't pose a problem unless you're using much larger valve and/or lift in the range I mentioned along with a tight lobe sep.
Ask yourself this, even stock Chevys, Fords, Pontiacs have valve reliefs in the pistons, why are there not any in any Olds, ever?
And as mentioned, take the extra off the rods not the rod journals. That helps minimize the offset. You basically said nothing there.
Please show me where I've given bad advice, please. I'll correct it. I've already shown where you did that, will you do the same? You haven't yet.
Have I charged anybody for any advice, ever? Please speak up if I have.
Bruce, imo you wiffed, again.
#61
#63
I don't know who's SBC 400 piston for a 5.7" rod you plan to use, someone mentioned Speed-Pro but Probe makes a good forged piston as does Pro-Tru which are far better than Speed-Pro's and they don't weigh as much.
How about we stop using my post as a battle ground for who is and isn't in the right. I got the info I needed with what internals to use that will make a nice block and I appreciate the help.
#64
I didn't mention a damn thing for what I was using. I simply stated that I can find pistons and rods for less than 685 that just those pistons cost! I never said speed pro never said anything for what I was using.
#66
BTR Performance offers those pistons, pins AND rings for $640. I have never heard anything negative about Bill as a business man. I have seen one of his motors run low 6's in the 1/8th at our local track. Good to have piston options, especially high quality ones.
#67
I'll post the set I'm talking about. Don't UBS to bring hate towards me I'm just saying that for my route that's insane to spend just that on pistons when I could get both for the same. And I apologize I thought it said 683. So I may have lied. I can get rods and pistons for a bit more than the 638 lol
#68
Geeeze you again?
Because it's stronger than a gas block.
Do you know how much abuse a stock Diesel crank can take?
Do you know the horsepower limitations of a stock Diesel crank ??
Maybe you should talk with some Super/Stock Olds racers, that have set world ET & MPH records with a stock Diesel crank in a Diesel block.
Again, you should talk with some people who are running a stock diesel crank.
Yes you could use a gas block 350 in the 400-500HP range, that's true, you could use a diesel block with a stock Diesel crank too.
#70
Seeing as how all Olds share the same style heads, explain this to us.I did an iron headed 455 with .584/.592 lift hyd roller, why did the valve not hit the pistons? I had over .150 valve to piston clearence, at overlap. Got any answers for that? Give an example of a build you've done that had over .580 lift where the pistons threatened the valves. I'm all ears. The simple truth is you're wrong. Olds valve angle doesn't pose a problem unless you're using much larger valve and/or lift in the range I mentioned along with a tight lobe sep. Ask yourself this, even stock Chevys, Fords, Pontiacs have valve reliefs in the pistons, why are there not any in any Olds, ever?
#71
#72
http://www.ebay.com/itm/SMALL-BLOCK-...-/170881189930
pistons I could not find for less than $500, but that does not mean they aren't out there.
#74
If not then I'd use the IC754 instead. That'll give you about 9.25:1 with the rest of the combo being the same as listed above.
And yes you can grind the side of those H-beams the same way you would anything else. Have both ends checked as well, they'll probably need to be opened up on the pin end.
#75
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Make sure you are getting the right pistons for the desired compression ratio and make sure they have floating wrist pins and not press in wrist pins because those H-Beam rods listed above look to be bushed on the small end.
There isn't any mention of + or minus balance on those rods, hope you have them checked and balanced on both ends.
Hope you are having this assembly balanced by a reputable machine shop that has a reputation on machining engines for racing.
You still going to need a 330/400/425 flexplate and a new dampner would be a good move since it has to be balanced with the crank and flexplate.
#76
[QUOTE=SBORule;472796]
Hope you are having this assembly balanced by a reputable machine shop that has a reputation on machining engines for racing. Why do they have to be race shop? Suppose they only do Chevy Race engines. Explain please.
QUOTE]
Just curious why that has to be.
QUOTE]
#77
[QUOTE=cutlassefi;472797]X2
#78
I have a couple reputable shops I will price out. I'll have those rods checked if I use them, with the correct piston to get the desired CR. Alongside the crank, flexplate and dampner.
Thanks for pointing out. I have the basics down tho for what to make sure of being checked.
#79
Lets see, hmmmmmmmm
Pretty much, that's why.
If you keep the stock stroke, grind the crank to fit those rods and use the piston listed, the KB IC753, then with a 65cc combustion chamber you'll have about 8.4:1 compression. Is that what you want?
