350 head question
Old Jan 9, 2013 | 04:05 AM
badass72cutlass's Avatar
350 head question
im gettin ready to rebuild a 350 i have a 1971 block, and i have 2 sets of heads, 1970 #6 heads, and 1971 #7 heads, which heads are the better choice? and why? thanks guys, btw, this motor is going to be mildly built using performer rpm accesories (intake and cam)
Old Jan 9, 2013 | 06:09 AM
Functionally the #6 and #7 heads are equivalent. The two differences between them are 1) the #7s used valve rotators on the exhausts only (#6 used them on all valves) so the exhaust spring pockets are deeper than the intake pockets. A good machine shop will shim the springs as appropriate so this isn't an issue. 2) the #7 heads have factory induction hardened valve seats, however if you plan to install larger valves or even if you cut the seats excessively for a valve job, you can easily remove this thin factory hardened area (making them the same as non-hardened #6s).
Bottom line is that there's not enough difference to matter.
young olds
Jun 3, 2014 08:13 PM
Olds Scott
May 29, 2013 08:15 PM
Ragtopw1972
Oct 18, 2012 08:19 AM
CLcutlass
Aug 21, 2011 06:25 PM
BerBer5985
Aug 13, 2009 03:04 PM
