350 carb/intake swap questions
Old July 17th, 2010, 07:05 PM
car_designer's Avatar
Ok, I have a '72 Cutlass with a 2bbl 350, with th350.
The 2bbl carb is messed up, so I would like to swap a q-jet with an edelbrock performer intake onto the 350.
Will a stock throttle cable for a 4bbl 350 fit/work with the quadrajet on a performer intake?
Will the original transmission kickdown cable from the 2bbl 350/th350 work? Or is there a different one for a 4bbl?
car_designer is offline
Old July 18th, 2010, 04:55 AM
The 2bbl and 4bbl throttle cables are different, but I've made the 2bbl cable work with a Qjet. You do need the Qjet cable bracket, which bolts to the two rear carb bolts. The kickdown cable goes through the firewall directly to the accelerator pedal - it doesn't interface with the carb at all on your car.
joe_padavano is offline
1972CutlassCar
March 3rd, 2014 06:09 PM
Shaunbo13
January 23rd, 2014 08:50 AM
drjr56
November 15th, 2012 07:20 PM
77GCSX
October 19th, 2011 04:30 PM
svnt442
July 17th, 2011 04:43 PM
Quick Reply: 350 carb/intake swap questions
