350 carb/intake swap questions
Old Jul 17, 2010 | 07:05 PM
car_designer's Avatar
Ok, I have a '72 Cutlass with a 2bbl 350, with th350.
The 2bbl carb is messed up, so I would like to swap a q-jet with an edelbrock performer intake onto the 350.
Will a stock throttle cable for a 4bbl 350 fit/work with the quadrajet on a performer intake?
Will the original transmission kickdown cable from the 2bbl 350/th350 work? Or is there a different one for a 4bbl?
Old Jul 18, 2010 | 04:55 AM
The 2bbl and 4bbl throttle cables are different, but I've made the 2bbl cable work with a Qjet. You do need the Qjet cable bracket, which bolts to the two rear carb bolts. The kickdown cable goes through the firewall directly to the accelerator pedal - it doesn't interface with the carb at all on your car.
1972CutlassCar
Mar 3, 2014 06:09 PM
Shaunbo13
Jan 23, 2014 08:50 AM
drjr56
Nov 15, 2012 07:20 PM
77GCSX
Oct 19, 2011 04:30 PM
svnt442
Jul 17, 2011 04:43 PM
