350 2 brl vs 4 barrel
If you don't have a carb or intake, get one of the carbs I mentioned with the Performer RPM intake. The Street Demon 750 or Qjet will run OK, especially a late 70's 350 or 403 800 cfm Qjet being an emissions carb. Then when you build your 403, just send it to someone like Everyday Performance to run properly with the bigger cam, displacement and higher compression. The Street Demon 750 has tuning kits and should run fine with cam you are planning out box but may need some dialing in with either motor to be ideal.
The OP has a heavy 1972 D88 with a 350 and likely low numerical gears. This car needs an engine built for low end torque in traffic, not high RPM HP. The base Performer will be a better choice than an RPM. A Qjet will be a better carb choice.
No, he has 3.73 gears and a 2000 stall, according to his other post. He is also planning on a .224/.224 .501/.501 Comp Cam in a 403 with early 350 heads. The Performer is OK and works fine with stock or near stock motors but he is planning a fairly decent 403, so a RPM is fine in the now AND better in the near future. Of course he will need electric choke and need to use block off plugs in the heads with the RPM. If he is planning on driving in sub freezing temps often, the Performer is a better choice. I agree, get a late 70's 350 or 403 800 cfm Qjet. It will be near perfect stock with just a rebuild but will need a recalibration with his future plans.
I WOULD suggest BBO heads on the 403, however...
it currently has the 350 with a mild cam the new stall an gears wont go in till the new engine
Decide whether you want a Performer or RPM intake for your 403, either will work with your current 350 just fine. The 403 or any late 70's 800 cfm Qjet will work with your current motor.
tcolt
Mar 16, 2017 09:58 PM
