330 Water pump pulley removal?
Old Aug 13, 2013 | 06:09 PM
at3reg98's Avatar
New 2 Olds
Question 330 Water pump pulley removal?
In the process of replacing the water pump and have the old one off the car. I notice that there is an aluminum spacer between the area where the fan mounts and the pulley itself. Is this a press fit where I need to rent a pulley remover? I can't get it off the pump shaft and don't want to damage anything using force.
Old Aug 13, 2013 | 06:13 PM
Grace Stinespring-Welch's Avatar
it might be corroded on there, soak it with pb blaster, then tap it loose.
Old Aug 13, 2013 | 06:14 PM
Oldsmaniac's Avatar
The fan spacer is not pressed on. It should come off with some hammer taps.
Old Aug 13, 2013 | 06:17 PM
at3reg98's Avatar
New 2 Olds
Silly question but I have been known to break things- safe to just use a mallet around the edges of the pulley to get it off? I'll have to try applying heat. I can't even get it to rotate.
Old Aug 13, 2013 | 06:24 PM
aluminum don't like heat
Old Aug 13, 2013 | 07:16 PM
TripDeuces's Avatar
There is a hole in the bottom of the spacer that fits over the water pump shaft. probably just dissimilar metals corroding. Keep tapping at it
Old Aug 13, 2013 | 07:26 PM
Octania's Avatar
Heat will help expand the AL
I believe it expands a lot more than steel does, and the steel will not be as hot anyhow, so unless you have a HUGE acetylene torch, go ahead and heat it judiciously.
Use penetrating lube and do not strike the pulley on the outer lip which is thin and fragile. Plastic coated "dead blow" hammer is recommended:
http://www.ebay.com/itm/64-oz-Dead-B...item2ec9841ac6
Old Aug 13, 2013 | 10:16 PM
at3reg98's Avatar
New 2 Olds
Got it off! I didn't realize that the tip on the spacer itself wasn't the pump shaft, no wonder I thought it wasn't budging.
I was surprised to find that what I thought was the original was an ancient reman pump, the sticker still on there.
sshriber
Feb 25, 2012 07:36 PM
ScottMHoffman
Nov 2, 2009 09:20 AM
longboardguy
Jun 25, 2009 04:48 PM
72Ctlss
Jun 23, 2009 03:12 PM
olds4life
Oct 10, 2008 07:28 PM
