330 valves
Old February 12th, 2022 | 02:37 PM
Paul Judd's Avatar
330 valves
I need 330 valves but i only see 350 are they the same i have #4 heads
Old February 12th, 2022 | 03:05 PM
I moved your post to its own thread instead of resurrecting an old unrelated one.
Old February 12th, 2022 | 03:49 PM
Yes, they are the same diameters and lengths.
Old February 12th, 2022 | 03:51 PM
Paul Judd's Avatar
330 valves
I need to replace valves but only can find 350 valves arethey the same i have #4 heads
Old February 12th, 2022 | 03:58 PM
ROCKETMAN269V's Avatar
OLDS ENGINE VALVES AT NAPA
1967 Oldsmobile Cutlass 5.4 L 330 CID V8 Search : valves
SEP V1770
Brand: Sealed Power
Exhaust Valve Stem Type: SG
Face Angle: 44 Deg.
Head Diameter (Inches): 1.562 in.
Stem Diameter (Inches): .3422 in.
SEP V1773
Brand: Sealed Power
Face Angle: 45 Deg.
Head Diameter (Inches): 1.876 in.
Intake Valve Stem Type: SG
Stem Diameter (Inches): .3425 in.
Old February 12th, 2022 | 05:14 PM
BillK's Avatar
Paul,
You will probably pay twice as much as needed at NAPA. Where are you located ? Did you ask your machine shop if they can get them for you ? I can get the intakes for $11 and the Exhausts for $8 Your machine shop should be able to match that price. Eloy brand from SBI
http://www.sbintl.com/
Old February 12th, 2022 | 06:19 PM
I merged your identical threads. You'll get a better answer sooner if all responses are kept in one thread.
Old February 12th, 2022 | 08:22 PM
Paul Judd's Avatar
does that include 77- 80 350s
Old February 13th, 2022 | 04:30 AM
brownbomber77's Avatar
Are you getting a valve job at the same time on the heads? May as well just stick some 1.62/2.00” valves in it. Same stem length. I can get you new valves for around $90 and performance springs for $70.
Old February 13th, 2022 | 07:09 AM
The 1977-80 350s got 1.875" intakes and 1.502" exhausts
blaker1
December 17th, 2014 06:32 PM
jjcus
August 12th, 2012 10:37 AM
optimus
November 30th, 2011 10:51 AM
jessejames
March 21st, 2009 01:48 AM
65cutty
August 27th, 2008 11:09 AM
