330 questions
Old September 2nd, 2017 | 11:23 AM
1slowbird's Avatar
330 questions
I picked up a 330 the other day with 65000 miles. I initially picked it up just to for the crank, flywheel, and balancer. However, after hearing the engine run, I'm thinking I may just put it in my Olds powered Trans Am. I was wondering if the 330 is a good engine to use for auto-x? Will the brackets and pulley's from the 403 bolt directly to the 330?
Mike
Old September 2nd, 2017 | 12:58 PM
330s are good engines, they just have a slightly smaller bore which gives them 20 cubic inches less displacement.
As for the brackets, I think they will all bolt up. I am not 100% but I think all second gen Olds engines have bracket holes in the same locations.
Old September 2nd, 2017 | 01:37 PM
Correct. All 1964-1990 SBOs are externally identical. The only POTENTIAL issue might be differences in mounting bosses on the intake - this depends on the specific intake you are using.
Old September 2nd, 2017 | 03:05 PM
1slowbird's Avatar
I'm going to use a spare edlebrock performer since I have to have an egr, and I'll put in a new HEI distributor. Also how can I tell if I need a 30* or 45* cam?
It came out of a 67 cutlass. How would the 330 handle running an entire course 2nd and 3rd gear? is the bottom end stronger than a 403? Is the loss of CI worth it?
Old September 2nd, 2017 | 03:34 PM
cutlassefi's Avatar
If it's a '67 it's probably a 39* block.
Yes it's stronger than the 403 but a properly built 403 will handle more than 450hp with no problem.
Old September 2nd, 2017 | 04:21 PM
jaunty75's Avatar
Originally Posted by 1slowbird
330 questions
OK, that's two. What are the other 328 questions?
Old September 2nd, 2017 | 08:36 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That looks like the 320 HP high compression version. Premium fuel should be used.
Old September 4th, 2017 | 08:53 AM
brownbomber77's Avatar
If you're just gonna run it, maybe replace the oil pump and timing chain for good measure. Stick a set of full roller rockers, 1.7, for a little more power. That Performer will at least take 25lbs off the front end.
Old September 4th, 2017 | 06:43 PM
2blu442's Avatar
It also came out of a car with California Emissions. So... you'll need to put small plugs (I think pipe thread) into the holes between the spark plugs. That's where the A.I.R. pump used to pump air into it. Then, the oil fill tube is the taller (10"?) fill tube. If its not full of dents you can sell that for $75-100 to someone putting the three 2 bbl carbs on their car. Those were the only two applications for the tall oil fill tube. You can replace the fill tube with a more common short one, or even one from a newer engine. John
Just to confirm, the 1967 would have come factory with #4 heads. The 1966 would have had #3 heads.
Old September 4th, 2017 | 06:50 PM
Those aren't NPT ports, they are inverted flare, like a brake line. You need IFM (inverted flare male) plugs.
http://www.plews-edelmann.com/invert...tube-fittings/
Old September 4th, 2017 | 07:46 PM
2blu442's Avatar
Thanks for clarifying Joe. I've got a set of heads with little brass plugs in them. Who knows, if they're the wrong thread a previous owner may have just torque them down and made them fit!
John
Old September 4th, 2017 | 08:06 PM
Canadian cars, at least my 81 Delta 88 307 had factory plugs installed. Great link Joe.
txrob779
May 20th, 2014 02:16 PM
REDJET
November 13th, 2012 02:22 PM
jag1886
December 2nd, 2010 03:43 PM
1964CutlassSC
May 8th, 2010 06:35 PM
Redog
July 11th, 2009 06:53 PM
Quick Reply: 330 questions
