330 parts on a 350?
Hi,
I believe it all should, the only thing to check to see if the crossover lines up as not sure if Olds made different ones, but you should see when you put a gasket from one to the other
Regards,
Regards,
The exceptions are the 260 motors and the roller cam 307 motors, both of which used tiny ports. The bolt patterns are the same, and you can physically bolt any SBO manifold to either of them, but the flow disruption caused by the port mismatch will be horrendous. Again, that doesn't apply to a 330.
Keep in mind that the flex plate on your 330 will not bolt up to the 350 engine as there are different bolt patterns between the early forged crankshafts (1967-earlier) and the later cast crankshafts. Everything else should bolt up with no issues as already said.
Yeah, we covered that in one of his other three or four threads on this same topic...
blaker1
January 28th, 2020 06:43 PM
