330 Olds Police cam
330 Olds Police cam
I was wondering if anyone here has run the Olds "Police Pursuit" / 442 cam in their 330. I have been having a time trying to find a cam grinder with an affordable 45 degree angle cam. I've found a place with cams for 110.00 !
Specs:
FINAL CAM CHOICE:
Year - Part# - Overlap - Duration - Lift Int./Exh. - Application
1964 387484 - 52 - 278/282 - .430/.432 - 330 Police Pursuit
This is part number 14-220 from Supercars Unlimited.
$109.95 with 15.00 shipping = $124.95
There is also this cam for the same price... the only difference is the overlap...
it's slightly less...
388992 47 278/282 .430/.432 J88 4BC, 330 4BC AT
I figure it should go in and work with minimal
fooling around,as it is a factory type cam...
any thoughts?? I'm looking for a slight cam note from
the exhaust and a bit more performance. This is my
daily driver... Cheers, Mike
Specs:
FINAL CAM CHOICE:
- Uses common .842 lifters.
- Should plug and play with factory specs… no shimming and/or mucking about with it.
- Should create a 300 HP spec engine.
oldsmosteel
February 28th, 2013 07:18 AM
Oldsguy
February 26th, 2010 05:55 PM
