330 heads for 350??
330 heads for 350??
Hey all! I have been lead to believe that 330 heads will bolt to a 350, potentially upping compression and flowing better then the crap heads on this later 350. Have read about the AIR bumps and whatnot, I have the following questions remaining.
- With a smaller bore, I would think that the heads would create hot spots/ high comp zones towards the edges of the cylinders where the larger and smaller bore lineup would result in a tighter area around the outside ring of the piston. Any potential for detonation? Not like the compression will be shooting through the roof or anything.
- I would obviously compare as I disassemble, but should I expect to see a much different top end setup? the 330 is a 66, the 350 I BELIEVE is from a later 70s. Should pushrod length match? Will all cooling / oiling ports align properly??
Any advice in general to this would be appreciated. Thanks!!
