307 Water Pump replacement
I'm changing the water pump on my 81 Delta 88, got the rad drained, hoses, fan and clutch assembly removed, and it started raining. So I'm stuck until at least tomorrow. The water pump pulley has seen better days, what can I do maintenance wise for the pulley? Would a soak in CLR, good brushing and a coat of rust paint a good idea or is there something else I could do to possibly minimize slipping?
![](https://cimg2.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/2000x1198/20161130_103915_154e026d0f02c9c277fc96cccbfeb546b55935da.jpg)
You do not need to remove the pulley from the pump; but, the pump does have to be removed. The pump stays in it's bracket, the bracket is removed and the pump comes along. The pump hoses do not need to be removed.
Pay attention to the advice to carefully note the spacer locations and not over tightening the small water pump bolts. Consider taking pics and color coding the spacers and their locations, if you don't you'll be cursing at the motor if you do you'll be thanking us.
And since this will probably come up at reassembly:
There are THREE fasteners that you need to loosen to adjust the belt, the two bolts on the front and the one nut at the bottom rear of the pump. Once you loosen all three, use a large screwdriver as a pry bar and insert it between the nose of the pump and the tab on the bracket, between the pulley and the bracket. The photo shows the proper position of the screwdriver with the pulley removed for clarity. Use the screwdriver to tension the belt while tightening the two bolts on the front, then get the nut on the back. Failure to do this properly is why there are frequent posts about belts squealing.
![](https://classicoldsmobile.com/forums/attachments/general-discussion/56553d1352041292-problem-alternator-belt-slipping-ps-pump-adjustment-sm.jpg)
Thank you both very much, I will heed all advice. I must be missing a bolt because I was convinced it was the pulley that had to come off next, I'm really glad it isn't. I definitely feel like I've bit off a bit more than I can chew here, but it wouldn't be the first time.
Since your question was about the water pump removal, the hardest bolts to get to are the AIR pump bracket that has to be removed first. I actually torched a hole in my 85 442's bracket to get to one last bolt.
OK, I got the power steering pump bracket off with the pump still attached. I'm glad I stopped and took the time to ask, because it made me slow down. I had already taken a bolt out that I shouldn't have. The first bolt I removed was the 15 mm through the pulley hole at the top right of the pump. (CSM Page 3B3-4 Fig 3B3-5 , the only bolt torqued to 35 ft. lbs) It's very clear to me now that I didn't need to take it out, because there was a spacer behind it. I know I have to get this back behind the bracket between the pump before I reassemble, has anyone else managed to do this without taking the pulley off? My first thought was to make a little tab like handle out of a piece of tape folded over itself to maneuver it behind the hole then feed the 15mm through.
BB,
Make sure to compare the new pump with the old one on the back side. When I did the 307 in my Wife's Riviera a couple of years ago something caught my eye on the new pump. The casting was not made properly and would not seal part of the gasket, probably causing a circulation issue. Pretty sure it was an AC Delco pump too
I forget what brand I got that matched the original one. Just make sure and look at it real closely. I might have some pictures somewhere, I will try to dig them up but they might be on the computer at my shop.
If you lay the gasket on the pump you should be able to see the problem if there is one.
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
Thanks BillK, I checked and the new one matches up with the old one.
Got up this morning and got the old water pump off and the front cover cleaned up before the rain started again. I wonder if I stopped buying car parts and new tools if I could afford a new place with a garage?
New water pump is installed, and torqued to proper spec. I got the power steering pump out back together and the bracket re installed. I hope to never have to deal with that power steering pump again. Put the belts back on and to proper tension, tried to start it up, and it isn't turning over. I'm going to start a new thread to inquire about the mess of vacuum hoses under the hoods.
Thanks for everyone's help, I would have screwed it up without it.
