307 rough start
Old May 11, 2013 | 07:04 AM
Black1984SNAPPING's Avatar
307 rough start
When it turns over its extremely rough like shakes the car. Its fine after I give it a little gas but it seems like not all the cylinders are firing right away or something. Any ideas?
Old May 11, 2013 | 08:18 AM
Lady72nRob71's Avatar
Is this on a cold start or does it do it all the time at idle?
How the performance of the car in general?
Give us some more clues to work with so we can help better.
I once had a rough idle after a cold start and the choke was adjusted slightly richer, never a problem after then.
Old May 11, 2013 | 10:08 AM
Yeah it happens on a cold start.
Old May 11, 2013 | 02:03 PM
Sounds like it is running lean.
Check for vacuum leaks in the miles of vacuum hoses first. Hoses disconnected or cracked.
Also check the hard plastic lines that go from the engine compt by the AC fan motor into the firewall, as those like to break.
Next make sure the carb mounting nuts are snug. Do not make very tight tho...
Any check engine lights? I assume not.
Once the computer takes over after warming up, it can compensate for the leak so it will run normal then.
Let us know what you find!
Old May 11, 2013 | 02:07 PM
Is the choke working?
colemane
Apr 13, 2013 01:19 PM
al714
Apr 25, 2011 03:47 AM
Destructor
Oct 22, 2010 05:35 PM
fritz442
Oct 12, 2010 05:12 AM
rrielley
Sep 1, 2008 03:00 AM
