307 with bad crank
Old Nov 16, 2006 | 10:32 PM
torquemonster's Avatar
Question 307 with bad crank
Hey just got registered. Have a bad crank in an 86 307 cutlass, had a barely noticable knock when warm. dropped pan only to find the forward most rod bearing had spun, heres the question , also have a good early 80's(with 5a heads) 307, will that crank and rod(s) swap into the 86 noting that the later one is a roller cam motor. Any advice would be appreciated. Would like to keep it as original as possible, so I don't want to drop in a different motor. Car had been parked since 02' and only has 34,000 original miles.
Old Dec 2, 2006 | 04:39 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
No the later 307's have full floating rods and different pistons. Not a direct swap as the early 307 have press fit rods.
Bernhard
Nov 24, 2022 09:12 AM
odddoylerules
Apr 21, 2014 07:54 AM
airmale
Nov 13, 2013 11:15 AM
67Olds442X2
Jun 14, 2011 03:51 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
